djm lower control arms
Old Jun 10, 2010 | 03:23 PM
07ScrewF150's Avatar
The instructions say to use a smaller tire, what does the size of tire have to do with the control arm?
And from what I can tell the djm arm lowers the truck by moving the bottom strut mount closer to the ground, is that correct?
I'm thinking about ordering the 3" model and use the strut set on 2" to achieve the ride height I want and hopefully get more shaft showing on the strut for a better ride. I would order the belltech spindles but you have to run a 20" wheel which right now is out of the question.
This place has the control arms for $195 and free shipping. Anybody ever ordered from them? http://www.streetsideauto.com/produc...ampaign=Become
Old Jun 10, 2010 | 05:39 PM
Fuerte150's Avatar
4x4?
Old Jun 10, 2010 | 05:53 PM
I'd call DJM and ask them what they mean by a smaller tire. Maybe overall diameter has to be shorter so you dont have tire to fender well clearance issues on your truck.
I had tire to inner fender clearance problems and i got them resolved with some trial and error on how much needed to be trimmed off of my truck.
Old Jun 10, 2010 | 06:11 PM
azmidget91's Avatar
yes on their lower kit they suggest a shorter tire, but you can get away with stock but you will hit your tires on the inner fender liners
Old Jun 10, 2010 | 07:00 PM
DJM needs to add one word to clear this up, diameter.
Old Jun 10, 2010 | 10:15 PM
bankrpt's Avatar
When I lowered mine 3.5/5 I ran my factory wheels and tires for a little wheel with no problems heck my 24s are taller than my 17s where and I'm lowered 4.5-6 now and only run in a really sharp curve you will be OK with your factory wheels and tires
Old Jun 11, 2010 | 09:03 AM
jsvo5695's Avatar
Does the lca have an offset balljoint? trying to find something to get my alignment back to 0.
Old Jun 11, 2010 | 10:42 AM
do you have room left to notch the hole some more on the lower control arm mounting points? If you are -1.7 I wouldnt think you would have to notch it much more to get it back to 0, but I am no expert by any means just thinking outloud here.
Old Jun 11, 2010 | 10:52 AM
FATHERFORD's Avatar
I ran stockers just fine for a long time after my 3/5.5 drop.
Old Jun 11, 2010 | 12:59 PM
jsvo5695's Avatar
I have the bolts over as far as the crossmember allows. I have the holes notched as far as possible.
The drop you have is what I ran for 3.5 years with the stock lca's. But with another 1.5 - 2.0 inches they won't cut it.
Old Jun 11, 2010 | 01:01 PM
sounds like you need a shorter length LCA
Old Jun 11, 2010 | 01:08 PM
jsvo5695's Avatar
Thats why I am looking at the djm lca.
Old Jun 11, 2010 | 04:14 PM
FATHERFORD's Avatar
I really don't think the DJM one is much shorter, if any.
Old Jun 11, 2010 | 04:22 PM
I know the 97-03 trucks the lowers are shorter and the uppers are a tad longer.
