Load capacity after lowering
Old Jan 20, 2010 | 08:21 PM
Carlsson3's Avatar
How much weight capacity do you lose after lowering? Towing capacity?
Old Jan 20, 2010 | 09:04 PM
bankrpt's Avatar
i really dont know but my truck is dropped 4-6" on 24s and i pull a 20ft car hauler with a fullsize truck on it from time to time with no problems i do use a torsion bar hitch
Old Jan 22, 2010 | 05:59 PM
depends on what parts are used to lower the truck.
I still tow with mine even being dropped 3/5
Old Feb 2, 2010 | 12:27 PM
AZ Mr. Bill's Avatar
Where I would worry about load capacity is when the frame is notched for axle clearance in a 6" rear drop. If the notch is not welded in properly you could have problems with frame stress in the area with a heavy load. With the standard shackle and hanger kits or just lowering shackles the only thing I would worry about then would be bump stop clearance; you have not changed the springs or modified the frame, you have only changed the suspension pivot points.
Case in point: On my 2001 F150, I have added 2" drop shackles to the rear, and have no problem adding 500 to 1000 pounds of gear to the bed, along with towing a 1000 pound trailer with a 150 pound hitch weight. It may squat a little bit, but it does not come close to the bump stops while sitting, and could hit them on a major bump, but I usually take it easy over major bumps anyway.
