one side higher then the other
Old Jul 30, 2008 | 07:12 PM
corey v's Avatar
my right side in the rear sits higher the the left and i need it to sit lower like the other i did what the instruction said but it didnt work has anyone else had this prob
Old Jul 30, 2008 | 08:06 PM
midnight08's Avatar
how much of a difference is there? and what kit was used?
Old Jul 30, 2008 | 08:22 PM
Arca_ex's Avatar
The truck just sits like that. It's completely normal. Mine sits about 3/4" higher on the left than it does the right. Stock ride height and lowered.
All F-150's do it even at stock height, because the gas tank is on the left side and so is the driver. When you have a nearly full tank + a driver it sits level.
Old Jul 30, 2008 | 08:50 PM
Robdude30's Avatar
What Arca said. Mine too.
Old Jul 30, 2008 | 09:47 PM
corey v's Avatar
its about 1 or so maybe less i used the belltech shackle and hanger kit for 2001 ford f150 screw my bad man its the right side of my truck
Old Jul 30, 2008 | 10:26 PM
Arca_ex's Avatar
Is it the drivers side or passenger side. Because now you confused me.
Old Jul 30, 2008 | 10:30 PM
corey v's Avatar
its the right side people iam sorry
Old Jul 30, 2008 | 10:57 PM
GerRod's Avatar
Mine is a little higher on one side as well.
Old Jul 31, 2008 | 12:44 PM
Robdude30's Avatar
Mine is actually higher on the right side as well. Didn't notice it before the drop mainly because I never really looked for it. On mine, you can't really tell unless you measure it, so I'm not too worried. The only thing I know of that you can do is to set you truck on level ground, loosen the front and rear leaf spring bolts and the rear shackle bolt (on both sides), then bounce the truck to get everything to settle in before tightening the bolts back up. May help, but only slightly. If it bothers you a lot, just put the helper bags on there with the pump and dual gauge setup. That way you can control the amount of air in each side individually.
Old Jul 31, 2008 | 06:45 PM
corey v's Avatar
well i called belltech and they told me to take the shocks off and if thats helps going to try it once my truck cools off
Old Jul 31, 2008 | 09:03 PM
Robdude30's Avatar
Did you get the Belltech shocks? I put the Street Performance shocks on mine. Please post back and let us know what you find out.
Old Aug 1, 2008 | 06:41 PM
corey v's Avatar
well no i havent replaced my shocks yet going to order them next week when i get paid, well i unbolted the shocks it didnt do a damn thing so i loosend the the rear shackle and it somewhat sits more even but not by much so hopefully when i get my new shocks put on it will sit right
Old Aug 3, 2008 | 08:18 PM
Robdude30's Avatar
I don't think the new shocks are going to make any difference even though they exert very little if any pressure. However, they are quite a bit shorter that the stock ones.
Old Aug 3, 2008 | 10:18 PM
corey v's Avatar
well really dont know what else to do man its frustrating
Old Aug 4, 2008 | 07:42 AM
OgRedd's Avatar
Ford may have been compensating for a full tank of gasoline which may (?) "even" the look. Do a test. Fill your tank to capacity, sit in the truck and let someone else take the measurements. I believe Arca is correct. If there's a difference, let us know. - Og
