Got My Drop Finished!
I'm not sure if any one out there has a 4" flip due to the nature of what a flip does to your rear suspension. Starting out, a flip by itself drops you 6", the Belltech flip (advertised at 5") gives you a 1" lift shackle to get you to 5" but in reality you end up around 5 1/2"(leaf spring sag?). I keep about 20 psi in my bags which levels me out with the front (3" drop) and gives me a true 5". This will put your frame about 2" from the rear axle and I rarely hit the bump stops (1/2" poly). The Belltech 5" flip is a really good foundation for lowering, all you have to do is find what you need to do to the front to match, and of course add the air bags if you want to use the truck for it's intended purposes.
http://www.djmsuspension.com/Product...4F150Parts.htm
Yes. I still have them. The ride is horrible with the Eibach leafs. The ride up front with the stock struts and GF springs is fine. Right now the ride is very mismatched, forgiving up front and extremely stiff out back. I thought for sure they'd loosen up by now with my truck being a 50 mile a day daily driver.
It's not. It feels like when on the road, with the 22's/40's it's more solid of course compared to the 17's/70's, front, back, front back, more give up front, much less give out back. If i go over a highway road hump at say 65mph the rear will react faster than the front after going over it. The rear finishes going over the hump after the front but finishes reacting before the front does. Am I making any sense?
Something is not adding up..........Your ride should be excellent
