subbox for supercrew
Clarion Cammo Sub
I picked up a Clarion Camouflage Sub through eBay for 85....Crutchfield has them on sale for 149.00. Bought the Clarion T-connector for the hookup thru Crutchfield for 9.99. Another guy used the T connector to input and power up the amps for 2-12" subs he mounted in the rear wall. You'll have to run separate power leads for the amps, but the inputs and amp turn-on should be usable with the connector.....Rube
Looks like your seat lift is coming along. Do the seats still latch properly? How much space (behind the seat) did you gain at the top and at the bottom of the seat?
The vinyl "booty" idea to cover the nuts will probably look good. Another idea I had is to cut some thin wall metal conduit to length, paint it to match the under-seat parts, and slip it over the nuts.
Keep us updated.
Keep us updated.
the seats still latch exactly the same after the lift and yea there is more space the whole lenth (top to bottom) behind the seat. I think that you could use anything really to be spacers as long as it was heavy duty enough to support the weight of passengers etc. and had decent surface area to let the bolt torque down real tight. that single latch behind the big end of the bench seat is ONLY a seat belt anchor point, and the latch mechanism is built into the seat hinges. when I get the seat belt anchor latch figured out maybe I'll sell a seatlift kit online? what about that?
