subbox for supercrew
Old Oct 14, 2002 | 03:35 PM
xsaccx's Avatar
Hi everyone,
I am new to this sight. I have a 2002 supercrew I was thinking of adding some subs, but I am not sure where I can put them. I have been looking at building a custom box behind the rear seat. I was wondering if anyone who has accomplished this could share some advice or ideas. all help is greatly appreciated!!
xsaccx
Old Oct 16, 2002 | 07:20 PM
hogrules's Avatar
sub box
check out this box from cructhfield
http://www.crutchfield.com/cgi-bin/S...FSC296&o=m&a=1
Also check out this box
http://www.subbox.net/store/index.html[/URL]
Do you plan on keeping your existing radio?
Old Oct 16, 2002 | 07:51 PM
chris_rod23's Avatar
I was looking for the same thing.
Anyone know how tough it is to install an amp to power the sub, using the existing radio?
Additionally, what about another amp to power the stock speakers, using the stock head unit?
Thanks for your input.
-Chris
Old Oct 16, 2002 | 11:48 PM
bigriggs's Avatar
I am putting 2 Diamond Audio 10" subs in a custom fit MDF box I am building to fit (only 3 sided) behind the back seats in my Screw. There is probably exactly enough room to run a 5 1/2"-5 3/4" mounted depth 10" sub. which is what I am fitting.
as for hooking up an amp to a stock head unit YES it is not hard. All you need is a line-level-adaptor, But you will only run your amp at about 70% of it's capability and as for putting an amp to stock door speakers OH yeah! you just have to make sure you use a good amp! cuz distortion kills speakers 99% of the time before overpowering them will. as for both amp setups to the stock HU you will lose your ability to easily up the bass output ( due to not having a fadind sub pre-out like an aftermarket radio). hope this helps. I can post digital pics of my sub install progress if someone can tell me what all I need to do. Later
Old Oct 17, 2002 | 08:58 AM
xsaccx's Avatar
bigriggs,
Thanks for the advice, I would love to see those pics and if you have any plans that you used I also like to see them if is not too much to ask. Thanks again.
Old Oct 17, 2002 | 07:00 PM
bigriggs's Avatar
I'm happy to give my measurements and post pictures but I have no idea how to post the pictures here. Help.
Old Oct 20, 2002 | 11:45 AM
Johnny150's Avatar
bigriggs
If you have the measurements and wouldn’t mind showing them, I would appreciate it. I’m having a hard time figuring out how to fit a 10 in such a small space.
Thanks,
Johnny
Old Oct 20, 2002 | 09:40 PM
bigriggs's Avatar
I put together a gallery. You should be able to find it by searching for "bigriggs" in the galleries I posted a few pics there and can email more to you if you would like.
Old Oct 26, 2002 | 11:00 PM
bigriggs's Avatar
subbox pics
https://www.f150online.com/galleries....cfm?gnum=1962
https://www.f150online.com/galleries/mygallery.cfm?gnum=1962]https://www.f150online.com/galleries....cfm?gnum=1962[/URL]
here is a link to my progress on my subbox for 2 -10" subs in a custom behind the seat box.
Old Oct 27, 2002 | 08:07 AM
xsaccx's Avatar
bigrigg keep those pics coming it looks good. WHat is the mounting depth of the subs.
Old Oct 27, 2002 | 09:02 AM
bigriggs's Avatar
The mounting depth is just a hair less than 5 3/4" (5 11/16th's?). I will probably cut out the sub's holes in my box today or tmw, and I'll add those pic's right after.
Old Nov 3, 2002 | 11:30 PM
cpharley2001's Avatar
I am selling my stealthbox for the center console. More info here: http://www.jlaudio.com/stealthbox/f150_CTR3.html I have had it 6 months and am selling $400 shipped obo.
Old Nov 4, 2002 | 12:40 AM
bigriggs's Avatar
more subbox progress and a seat lift!
I think this link should work?
I got both sub holes cut into my box and I think I will do the side plates in the next day or so. I also needed to make a little more room behind my seats so I went to Home Depot and bought some longer bolts to bolt my rear seats to the floor ( 10-1.5mm x 50mm) and stacked two 5/8th inch nuts to be my 1.25" spacer. It works great, the seat folds up and down fine and I have alot more room behind the seat to use. I will post a pic probably tommorrow of the seat lift stuff.
Old Nov 4, 2002 | 09:11 AM
Robdude30's Avatar
Thumbs up
bigriggs, Please let us know how the seat lift works out! Include detailed pics and instructions. I have been trying to figure out how to get a large sub behind my seat and it sounds like you may have figured it out.
BTW, your back wall is coming together very nicely.
Old Nov 4, 2002 | 11:34 PM
bigriggs's Avatar
here are some pic's of my seat lift progress and my subbox progress.
