Sub & Amp Installed
Old Aug 11, 2002 | 03:21 PM
Habibi's Avatar
Sub & Amp Installed
Hi!
Just got a sub and amp installed.
It was a package from PowerAccoustik.
It's not super high tek like some of you have on here, but man, what a difference it makes.
The amp is mounted under the 40% rear split seat, and the box is placed on the middle hump.
It works out pretty well because I can just unplug the box from the amp if I ever need the space.
Not only that, but the box helps the hounds get from the back seat, to the front much easier.
Here's a few pics
Habibi
Old Aug 11, 2002 | 03:23 PM
Habibi's Avatar
This is what it looks like in place
Old Aug 11, 2002 | 09:40 PM
p_ferlow's Avatar
Looks nice! What model and size sub is that?
Old Aug 11, 2002 | 10:17 PM
Habibi's Avatar
Not sure of the model number.
I think it's an 8 inch sub, and the package came from PowerAccoustik.
The amp was mounted on the back of the box, but I screwed it to the seat bottom to make more room.
(The passenger seat couldnt go back very far when the amp was screwed to the back of the box.)
Now it can go back "almost" all the way.
Not bad for $400 canadian, including install and taxes.
This thing pumps out loads of bass, nice and tight sounding.
I can't get over the improvement in sound, it like a new stereo.
I'll try to dind out the exact model number and get back to you.
Regards
Habibi
Old Aug 21, 2002 | 02:21 PM
Madd's Avatar
I am about as excited about it as the dog is.......
Old Aug 21, 2002 | 03:02 PM
justy3099's Avatar
one thing to consider is on most amps i've seen, they say in the directions to NOT mount them upside down. The install looks good, but check this out. HEat rises, and on most amps mounting them like that will cook them.
Old Aug 22, 2002 | 08:43 AM
Rugby3's Avatar
I agree nice stuff, but I would definately change the way the amps are mounted. The sides and top are used as a heat sink, to dissipate the heat the amp makes. Some amps do run very cool, not many though. Most run HOT. Heat kills em.
Good Luck
Old Aug 23, 2002 | 04:36 AM
svtoby150's Avatar
Pretty cool
I got to agree, amp upside down=too hot
looks like the you have the amp bridged also, correct? That will heat things up a bit more mounted like that. Prolly won't have any problems until you crank some bass for a while, it'll prolly cut out.
Old Aug 23, 2002 | 09:42 AM
ROUSHFAN-1's Avatar
what the heck kinda plug do you have going to the box???is that a trailer plug?? why didn't you just get the bannana plug that fits in the box terminals?? ohh yeah move the amp..heh heh..stick it under one of the front seats so it's still out of your way..
