adding componets
Old Jan 7, 2002 | 09:05 PM
andrewjhaley's Avatar
Question adding componets
I want to add some mq quart componets in my door, preferably 7inch midranges, which i guess is the 6.5 but they call it a 7inch for this perticular model, after cutting up the hole where the stock speaker fits, will this speaker drop in? how much would custom kicks be?
Old Jan 7, 2002 | 09:22 PM
WOLVERINE's Avatar
I don't know much about the mq quart speakers, but the Q-Forms kick panel pods will run you $199.95 a pair at Crutchfeild. They have great imaging and they are custom made for your specific vehicle. Well worth the money IMHO.
Old Jan 8, 2002 | 04:18 AM
Deus's Avatar
Most of the qforms will fit up to a 5.25". Some of them fit 6.5s. You will have to call and check. Go with custom fiberglass kick panels if your wallet allows.
Old Jan 11, 2002 | 06:29 PM
haze10's Avatar
I would be careful putting a 7 inch in the door. First, I think it won't fit well, and second, that would be a lot of power for that thin piece of sheetmetal. May cause a lot of vibration. If you have to do it, then reinforce the hell out of it with MDF, and dynamat the whole door.
Old Jan 16, 2002 | 08:19 PM
brokeagin's Avatar
I do not know which model you are going to use. But mine are PSC216's and all I had to do was cut just a little out of the door to get mine to fit. They cleared all of the stuff in the doors just fine. I used a composite plastic to make and adapter which helped. I checked and they won't fit in the Q forms unless you space them out. Hope this helps...
David
Old Jan 16, 2002 | 08:29 PM
btolenti's Avatar
try www.thezeb.com. They have the Q-forms for 149.99 plus 10 s+h...
Old Jan 31, 2002 | 05:31 PM
BJays Red 150's Avatar
For those of you who have put larger drivers in your doors, can you please post pics/instructions as to how it was done? I'm installing a 3-way comp set next week so I gotta find out!
Old Jan 31, 2002 | 06:21 PM
brokeagin's Avatar
Sorry I do not have many pictures (there are a few on my website at http://www.geocities.com/brokeagin that you can check out if you want). But what I was faced with was when the stock speakers (and the 6 1/2's) were installed in the factory holes, almost half of the speakers was hidden behind the door panel to the front of the grille. I moved the speakers to the rear by enlarging the factory hole by cutting a half moon section out of the door. I took a piece of 1/2" thick composite material and cut it big enough to cover the now larger hole and mounted it to the door. I then mounted the speaker to the composite material. Now the speaker is centered more in the door panel speaker grille. Questions???
David
