rear speaker problem
Old 09-11-2011, 11:57 PM
Johnnyjb's Avatar
So my rear speakers work very oddly.
If i set my fade to only he back and my balance ALL THE WAY RIGHT OR ALL THE WAY LEFT, my two back speakers work perfecly fine. But if i set the balance to 0 is all weird and messed up.
So i though changing the speakers would work...
and i was wrong, they still do it
hey are really holding my sysem back
Old 09-12-2011, 06:31 AM
Norm's Avatar
Is this a stock system? If not something is wired wrong or you used a summing LOC also wired wrong.
Old 09-12-2011, 09:11 AM
Johnnyjb's Avatar
No it's aftermarket
At what level is the wiring wrong
Cause I'm not good enough to take slot apart
Old 09-12-2011, 09:45 AM
4.2xl2001's Avatar
It sounds like you have the negative from each rear speaker mixed up at the head unit. Switch the two negative wires and keep the positive wires connected the way they are.
Old 09-12-2011, 04:35 PM
Johnnyjb's Avatar
i took my head unit out and started playing around and its fixed
now my system acually sounds pretty bad ***!
Thanks guys!!!
Quick Reply: rear speaker problem
