Sub question
Old 08-04-2011, 12:24 AM
droman2's Avatar
Sub question
So recently I upgraded my headunit and now im looking to add a bit of bass. A buddy of mine has 2 JL 10w3d4 that he is willing to give me with a Phoenix Gold Tantrum 500.2. My question is will this setup work well together, and would these subs fit in an under the back seat enclosure without modifying the box?
Old 08-04-2011, 09:22 AM
TX05F150's Avatar
This setup will work. Bridged at 4 ohms that amp puts out 500 watts RMS. Those subs handle 250 each. As far as the enclosure you would have to build one or pick one up from Fox Acoustics due to the 5.8 mounting depth of those subs. Sounds like a nice guy to just give you 2 subs and an amp
Old 08-04-2011, 04:27 PM
droman2's Avatar
Lol yea he was a nice guy. I figured if i ran the subs parallel down to 2 ohms I could run them off of each channel @ 250watts. Didn't think about bridging the channels how would you wire this up?
Old 08-04-2011, 04:59 PM
TX05F150's Avatar
Your right you could just run them parallel.
Old 08-04-2011, 05:29 PM
Ray21's Avatar
Wire the subs in series separately, then parallel them together. That'll get you a final load of 4 ohms.
Or you can run them off each channel w/o bridging the amp.
Old 08-04-2011, 06:47 PM
droman2's Avatar
Ive never bridged an amp before Ive heard it could shorten its life. Do any of you guys know a box that will fit these under my rear seat? something not crazy expensive, or have dimensions so I could build my own :]
Old 08-04-2011, 07:44 PM
TX05F150's Avatar
Check out my first response.
Old 08-05-2011, 04:03 PM
droman2's Avatar
do you think they would mount in this box or no?
http://cgi.ebay.com/2004-08-FORD-F15...item564326e249
Old 08-05-2011, 04:20 PM
TX05F150's Avatar
They will not fit. That box has a speaker depth of 5.75 and the mounting depth of the JL subs are 5.8
Old 08-05-2011, 04:21 PM
droman2's Avatar
on the JL literature it says 5.75
http://mobile.jlaudio.com/pdfs/10W3v2_MAN.pdf
Old 08-05-2011, 05:32 PM
TX05F150's Avatar
Strange I looked at the manual too. Maybe I accidentally opened the manual for the wrong subwoofer on the JL website. Yes then it should work. I would be cautious though about buying a box that cheap. Try and do a little research on the company to see what others have said about them.
Old 08-05-2011, 05:40 PM
droman2's Avatar
yea they want 50 dollars shipping, a guy on the web i found said he could make one for 138 + shipping but it would require a seat lift. That doesn't seem like a bad price. But even for 100 i guess the mounting depth of the other box depends on the size of the magnet seeing as its on an angle. I could just buy the ebay box and if it doesn't work use it as a template to make a larger one. :]
Old 08-07-2011, 12:28 PM
TX05F150's Avatar
Go with a supercrewsounds box. Good build quality I used to have one for a single 10
Old 08-07-2011, 12:35 PM
TX05F150's Avatar
You could go with this box and add the optional extended depth to fit your subs.
http://www.supercrewsound.com/04F150ECUTSdual.html
Old 08-07-2011, 10:18 PM
droman2's Avatar
I got a question for you guys. I got all my wires run and subs plugged in, if I leave it on low they will work just fine but as soon as i add volume the subs will push once and then just pulse every 4-5 seconds. The power light to the amp flickers every time this happens. Any ideas? I ran them series and bridged the amp. so they should be running at 4 ohms.
Quick Reply: Sub question
