couple sub questions
i got a couple questions
1. how much width do i need for a 10" sub. they way it will sit my box is gonna be 11.5 wide on the outside and 10 on the inside. the sub only needs a 9 1/4 cutout so would that work?
2.i have a 400 watt 2 channel amp and was wondering if i could hook the two channels together and use them both to get more power to the sub.
I'm also running a kicker CVR 10" 4 ohm sub, they are rated a 200w rms per coil or 400w total. you can run more to it but be careful. I'm pushing mine with a kenwood 8404D and its rated at 500w rms @2 ohm and I have the sub wired up in a 2 ohm load and its just fine but I don't push it too hard for very long.
The 12volt has a good section on wiring your subwoofers to your amplifier
http://www.the12volt.com/caraudio/wo...igurations.asp
See page 9 "the first wiring diagram" on the 400-4 owners manual.
http://www.rockfordfosgate.com/rftec...Pwr4Ch-MAN.pdf
From that you would wire the sub for 4 or 2 ohms.
See the12volt.com for that.
