2 15" L7's question
Old May 3, 2010 | 12:31 AM
Toyz's Avatar
2 15" L7's question
Rookie question about wiring these dual 4ohm subs. I just built a friend a solid 9cf slot ported box tuned to 33-34hz and he is ready to hook them up. I can build nice boxes all day long but when it comes to wiring, its been a while since Ive hooked up dvc 4ohm subs.
Hes running them on a 2500.1 kicker 2ohm amp. How would I run them to 2ohm stable. If I remember right it would be in parallel? Which means pos of one coil to neg of the opposite coil on each sub, then neg to negative on the drivers to the amp? and poss to poss driver to amp? Brain fart...
Thanks in advance.
Old May 3, 2010 | 11:21 AM
Toyz's Avatar
Never mind, got it
Old May 4, 2010 | 05:31 PM
fine_style150's Avatar
you can always refer to rockfordfosgate.com for ohm wiring on speakers
