Factory audiphile sub HELP!
Old Apr 29, 2010 | 04:33 PM
kens fx4's Avatar
Exclamation Factory audiphile sub HELP!
i have an 04 f-150 that does NOt have the wiring for the sub.
i have the audiophile head unit ( the third plug was there of that)
i also have the factory sub.
but how do it get it wired to work? can't find a wire harness anywhere
sorry i'm not good at reading/understanding wiring diagams to make one
myself
anyone have any help
thanks
Old Apr 29, 2010 | 04:37 PM
GATORB8's Avatar
Are you saying you have the front connector/harness that goes into the head unit, but you can't find the rear part?
Old Apr 29, 2010 | 10:47 PM
Brad Johnson's Avatar
Odd. If you have the wiring in the dash the wiring for the sub should be there as well unless some industrious soul took it upon themselves to remove it.
Brad
Old Apr 30, 2010 | 01:49 PM
gonecrazy's Avatar
i just took my rear seat out today and the plug is taped to the floor under the carpet on the drivers side
Old Apr 30, 2010 | 02:30 PM
Yogi.kudos's Avatar
Heres where the rear should be. Under the rear drivers side seat.
Old Apr 30, 2010 | 09:28 PM
kens fx4's Avatar
yes i'm saying i have the pulg under the dash for the head unit, but no plug in the rear sor the sub.
i found the hole oner the rear seat where it shoule be and felt all around and no luck...
where does the wires head to after the go under the carpet?
down to the door? or what..
thanks
Old Apr 30, 2010 | 10:09 PM
gonecrazy's Avatar
thanks
Like i posted earlier, I removed my rear seat today and my plug was taped to the floor under the carpet. you might need to take your seat out to get the carpet up or pop of the trim at the door holding the carpet down to slid you hand under
Old May 1, 2010 | 03:21 AM
phattacorider's Avatar
Curious, I'm gonna have to see if I have one as well. My XLT came with a basic CD player with mp3 playback and an aux input but there's a 3rd harness behind the radio that I never knew what it was meant for. Looks like I'll be spending a quick portion of my weekend taking a peek under the carpet of my rear driver-side seat!
Old May 2, 2010 | 09:19 PM
kens fx4's Avatar
looked again this weekend
no luck in finding it.
Old May 3, 2010 | 03:49 AM
Later today I'm gonna remove the subwoofer under my rear seats to make a bunch of enclosures to sell. If I find mine (if it's there), I'll take pictures of it. I know I'll have to get under the carpet, but if I find it, CLICK!
Old May 4, 2010 | 08:32 PM
kens fx4's Avatar
ok.. update
i took out almost all of my interior.
front seet, rear seat, all side panels, door sills..
pulled up carpet as fas as i could.. had my hand arm all the
way from the firewall to the rear seat and in to the center hump..
No wires for sub...
the only think left and its a long shot, take the back of the rear seat off
there are a big pile of wires that go behind it.
so... i give up
Old May 5, 2010 | 09:51 AM
GATORB8's Avatar
You can make the harness, won't be too bad since you have the connector for the head unit already.
