Factory sub & amp with aftermarket H/U
I’m trying to install a Clarion CX609 in my truck. I’d like to be able to use the factory amp and subwoofer (for now anyways). I found a harness kit that provides the RCA jacks I need to connect the Clarion to the wiring harness. It even includes two resistors to make a voltage divider for the enable signal.
Looking at the Ford wiring diagrams it looks like there was a mono signal going out to the amp from the factory HU. Now the harness connector has two RCA jacks but I think only one channel actually has a connection to the amp.
Is my system going to sound lacking only running off one channel? Anyone know of a way to sorta bridge the stereo signals into a mono signal?
thanks
thanks
Yeah, when I think about it most any music I listen to the low bass stuff is pretty much common to left and the right side so I guess it should sound fine just using one side.
It also seems this Clarion unit has a low pass filter and adjustable output levels so I think this is going to work. I'll let you know how it goes.
