Subwoofer Help Please.................
Screw it.... This is what I am going to go with.
Enclosure
http://www.crutchfield.com/S-7lcPBk7...res-Black.html
Amp
http://signature.crutchfield.com/s_1...v2.html?tp=115
Sub
http://signature.crutchfield.com/s_1....html?tp=27741
I don't think I can go wrong with this setup and hopefully it hits way harder than my setup now.
Enclosure
Amp
Sub
http://www.crutchfield.com/p_500MRPM...00.html?tp=115
If you wasn't in Austin I would let you hear it
I don't believe that box will fit a 10W3V3. It says mounting depth is 5.8125 for the box, 5 7/8 = 5.875. Nope, won't fit without an aforementioned rubber ring of some sort or a spacer - which I would shy away from.
Fox does make a single 10" sub box that will fit a 10W3V3 though:
http://www.foxacoustics.com/ProductD...de=F150-110-04
Would it actually benefit me to dynamat the rear wall of the truck? I have some rattle back there and was wondering if this would cure this and maybe give me better bass response inside the truck. Any thoughts anyone? I mean if I am not going to notice a noticeable difference in the above two things I would rather not spend $200 bucks getting it done.
