best speakers for around $100 per pair??
I blew one of my stock rear speakers, now I have a reason to upgrade.
I have the stock base system in a 2006 F150, and would like to replace all 4 speakers.
What is the best speakers to replace mine with, that would work best with a stock head unit??? I'm looking at around $100 per pair to spend ($200 total for all 4 speakers).
THanks for any sugestions. :santa:
You can go with Infinity Kappas that sound great for 79 a pair. My friend owns a audio shop and tells me that those are the best for the money.
http://www.sonicelectronix.com/item_...a+682.9cf.html
Check out Crutchfield. They have some pretty good offers going on both Infinity and Polk.
I am a fan of both. I had to put Infinitys n my G due to needing 2 ohms to match Bose amps. I had Polk in my previous car and reall like them. I will be getting one or the other when I upgrade my Expd speakers.
I looked at crutchfield for that speaker, crap crutchfiled is EXPENSIVE. They want $140 for that pair where I can get it for $79.
I also can get the Polk DB571's for $70 on Amazon, Crutchfield wants $100.
Hmmm, good website but they are pricey, just a heads up for anyone looking at their stuff.
Those look like the best performance for the $ so far. I also looked at polk DB571.
I have always had great luck with Crutchfield. You get any hardware or wiring hrnesses needd for the install, and great tech support if needed. I had a problem with a Crutchfield brand amp, about 2 months after teh warranty was up, I called to see about repair. They ended up sending me a brand new at no charge. I would rather spend a little extra and have great customer sevice, if I ever need it.
* Damage due to improper installation.
* Subsequent damage to other components.
* Damage caused by exposure to moisture, excessive heat, chemical cleaners, and/or UV radiation.
* Damage through negligence, misuse, accident or abuse. Repeated returns for the same damage may be considered abuse.
* Burnt voice coils (blackened, no continuity, melted adhesives, coil separated from the former).
* Blown speakers or tweeters
* Punctured or damaged surrounds.
* Broken speaker terminals.
* Bent, chipped or broken frames.
* Ripped spiders or damaged back plates.
* Any cost or expense related to the removal or reinstallation of product.
* Speakers damaged due to amplifier clipping or distortion.
* Electronics damaged due to amplifier clipping or distortion.
* Items previously repaired or modified by any unauthorized repair facility.
* Return shipping on defective or non-defective items.
* Products with tampered or missing Sonic Electronix labels or specific manufacturer serial numbers, tags or labels.
* Products returned without a Return Authorization (RMA) number.
* Freight Damage (goods damaged due to shipping must be reported within 7 days of delivery)
* The cost of shipping product to Sonic Electronix.
* The cost of shipping product from Sonic Electronix upon completion of repair or replacement.
* Service performed by anyone other than Sonic Electronix.
you call that a warranty
