Build me a system...
Old Mar 25, 2009 | 08:36 PM
  #61
pylda's Avatar
What is wrong with this picture?
Here is a quick attempt at how I think the basic wiring of my system will look like. Im new to this. Where did I go wrong?
I am planning on purchasing the following items:
6.5 Components
2-channel Amp
10' Sub
Sub Amp
Speaker Wire
RCAs
Power Wire
Distro Block
Heat Shrink Tubing
Heat Gun
Zip Ties
Adhesive Mounting brackets
Sound Deadener
What else??
Can I mount the crossovers for the comps on the back wall with the amps?
Thank you guys so much for the tips you have shared so far. The plan is to built an amp rack behind the rear seat and run the 1/0 power wire underneath the truck.
Old Mar 25, 2009 | 08:39 PM
  #62
pylda's Avatar
Also....
How much deadener should I buy for the rear wall, 4 doors, and floor?
What length RCAs do I need to get from the HU to the (SCREW) rear wall?
How much speaker wire total ft? What size?
How much power wire total ft?
Old Mar 25, 2009 | 08:50 PM
  #63
mSaLL150's Avatar
Only 1 set of RCAs from headunit to 2 channel. Only 1 set of speaker cables (pos and neg) from 2 channel to each crossover.
