sub box problem?
Old Dec 16, 2008 | 03:25 PM
abervintageman4's Avatar
Originally Posted by willys5555
yep and i have all the measurments figured out so it wouldnt take much time. I think i will do it when ever i have time...probably not til next weekend though.
how would you suggest i attach the port to the box? just like some apoxy?
i thought about this too, i was going to just use pvc and make it a tight squeeze into the hole(thats sorta what she said) and then seal it up, epoxy works, but i would brace the port on the inside of the box as well depending on how long the port is going to be
Old Dec 16, 2008 | 08:15 PM
willys5555's Avatar
hahaha thats what she said. and yea i was thinking about putting a little scrap of MDF in there to hold up the back of the port and apoxy it to that also. then for extra good measure maybe i would put some caulk on the outside also.
Old Dec 16, 2008 | 09:11 PM
ya sounds like a plan, i wanna hear this next time your at the meet, nvr heard an under seat ported box, then you can finally hear my cvr's, i got a new amp friday so its workin again
Old Dec 16, 2008 | 11:03 PM
willys5555's Avatar
definetly...i am not sure when i will be able to come out again though. i have been really busy and now with christmas so close...it will start to be "family time" but i want to come out soon cause i want to buy the running boards from coobies. but i gotta get that money together.
Old Dec 17, 2008 | 02:01 AM
Low_e_Red's Avatar
The easiest is the she said way. But then with that port a bit of wood glue to reinforce will be enough.
Old Dec 18, 2008 | 08:25 PM
willys5555's Avatar
ok well i got the seat back in and it looks great and is still functional! i will get some pictures up probably this weekend...but i have some bad news. my subs arent working and i think a possible amp blown. check out my other thread if you think you have a fix. any help is greatly appreciated
https://www.f150online.com/forums/am...ml#post3496497
Old Dec 19, 2008 | 10:10 PM
willys5555's Avatar
ok well i got everything fixed and have it completely installed. sounds great! here are some of the pictures of it. i have more in my album so go check that out.
https://www.f150online.com/forums/me...eo-system.html
what do yall think about it?
