Audiophile wiring help!
Old May 12, 2008 | 08:38 PM
Sandog53's Avatar
I have the sub, I have a factory harness plug out of an 08, and my truck is an 07. My question is this, all of the wiring shows that the plug has more wiring in it than the plug I have. I have 2 sheilded wires, and 3 other wires totalling 5 wires. I imagine the two shielded go to the radio, the small unsheilded is the enable, and the two thick is power and ground, which is which?? I did a search and did not find the answer. I have the following
Purple/Blue 10ga
Black/Orange 10ga
Green/Purple 16ga
Tan/Orange-sheilded
Pink/Black-sheilded
Help please!
Old May 12, 2008 | 09:04 PM
GJ Screw's Avatar
Purple/Blue 10ga --Ground I think..
Black/Orange 10ga -- Power I think..
Green/Purple 16ga -- Remote Turn on
Tan/Orange-sheilded -- Maybe Brown/Orange? If so it is +
Pink/Black-sheilded -- Maybe Red/Black? If so it is -
Help please!
Hope this helps a little?!
Jon
Old May 12, 2008 | 09:17 PM
Sandog53's Avatar
I will try it, better than nothing. Which pin will they corres
pond with in the dash?? I will ground the one in the kick, and run the 12v to the fuse block.
Old May 12, 2008 | 09:32 PM
GJ Screw's Avatar
https://www.f150online.com/forums/sh...d.php?t=184256
Check that out....
Jon
Old May 12, 2008 | 09:47 PM
Sandog53's Avatar
Yeah, I have been there, my plug does not have as many wires as those plugs, that is for the 04-05, mine is an 07. Thanks though!
Old May 12, 2008 | 11:40 PM
GJ Screw's Avatar
How bout this one?
https://www.f150online.com/forums/sh...d.php?t=320851
Jon
Old May 13, 2008 | 02:07 AM
Sandog53's Avatar
I got something wrong with mine, I hooked it all up and it keeps poppin the fuse, checked all my connections, ran new wire, did the same thing, checked the diagrams, worked on it for awhile, just keeps poppin fuses. Do you think the amp is bad??
