Carpet on the box under subs
Old Mar 1, 2008 | 12:21 AM
shanecaseber's Avatar
will the carpet stop the sub from sealing will it not make it air tight or shoud I trim the carpet around the sub at mount points?
Old Mar 1, 2008 | 12:41 AM
ModBargains's Avatar
I have my sub screwed down around the carpet and havent had any problems...I think most of the subs are that way.
Old Mar 1, 2008 | 09:08 AM
F150Truck'in's Avatar
I would NEVER have carpet in between sub and wood on a sealed box, if ported maybe it would be fine, but I still wouldn't no it then..
Old Mar 1, 2008 | 12:06 PM
trublueFX4's Avatar
I havent had any air leakage with the sub being over the carpet. if you are worried, just put some RTV silicone (the stuff you use to seal a box) around the edge of the opening before placing the sub in
Old Mar 1, 2008 | 01:29 PM
Low_e_Red's Avatar
Thats smart... Especially since carpet is air tight....
X2!! F150.
Old Mar 4, 2008 | 05:50 PM
CCnCoke's Avatar
Just curious - where are you guys finding the actual carpet? I've looked everywhere without luck.
Old Mar 4, 2008 | 07:23 PM
Bartak1's Avatar
You will NOT get a seal with the carpet between the box and the sub.
Screw the sub in with the carpet in, take a utility knife and cut into the carpet around the outside of the sub, then take the sub out and pull the carpet off...
