The war has begun, won the first battle but was a Bit*h
Old Feb 22, 2008 | 12:31 AM
  #31
Bartak1's Avatar
I had always planned to use the expanding foam in my C pillars and little back doors too.....but I have never done it before.
Is it actually worth it? I would think it would have to make things more solid and maybe absorb some sound, but Ive never seen a whole lot of proof.....
Old Feb 22, 2008 | 12:32 AM
  #32
andrewc_11890's Avatar
How thick is that peal and seal stuff? cause you were able to put it on the backsides of the panels im assuming not too thick? does it still work decent if it isn't that thick?
Old Feb 22, 2008 | 12:33 AM
  #33
Tuff4rd's Avatar
Originally Posted by Bartak1
I need to deaden my truck bad. This summer perhaps.
Where are you going to mount the amps, Tuff?
Looking good so far, keep it up
Im going to flush mount them to the top of the sub box. Im hopeing the box is no taller than 14 inches.
Old Feb 22, 2008 | 12:37 AM
  #34
Tuff4rd's Avatar
I would say it about the thickness of 2 or 3 CD's stacked
Old Feb 22, 2008 | 12:49 AM
  #35
Tuff4rd's Avatar
Originally Posted by jmt0645
he may not have but i did PITA but worth it IMO. did you use expanding foam in the backwall, if not we got one better! J/K. but it does help too.
How long did it take you to do that?
Did you guys find yourself knocking on the walls and banging on the floor to see how the sound changed as you applied the deadner?
Old Feb 22, 2008 | 01:29 AM
  #36
styxnpicks's Avatar
Did you guys find yourself knocking on the walls and banging on the floor to see how the sound canged as you applied the deadner?
I still havnt done my drivers door, I like to use it as an a/b comparison
Old Mar 6, 2008 | 02:45 AM
  #37
Tuff4rd's Avatar
The sytem is pretty much done. I made my own sub box and amp rack, just need to finish up the amp rack cover.
I will be posting pix on the final install in a couple of days
Old Mar 6, 2008 | 11:08 AM
  #38
bigtex44's Avatar
I know it hasnt been hot the last couple of days (here in Houston at least), but how's the smell of that peel & seal? I can only imagine what it would be like during one of those hot McAllen summers.
I'd love to use peel & seal (at least for my floors), but I'm scared of my truck smelling like a steam roller just ran through it.
Old Mar 6, 2008 | 11:11 AM
  #39
styxnpicks's Avatar
buy butyl based deadener then. no smell and better viscoelastic properties
Old Mar 6, 2008 | 11:25 AM
  #40
bigtex44's Avatar
stix - I was just going through your install gallery. What type of sound deadening did you use on your floors? Is that asphalt or butyl based? If asphalt based, did you have any issues with smell? I'm just looking for input, because I don't have any experience with asphalt based deadening, but I'd try it to save a couple bucks.
Old Mar 6, 2008 | 11:34 AM
  #41
styxnpicks's Avatar
its butyl based. I found it cheap on ebay... stay away from fatmat! I recommend rammat or second skin
Old Mar 6, 2008 | 12:01 PM
  #42
Low_e_Red's Avatar
Or dynamat.
Old Mar 6, 2008 | 12:31 PM
  #43
styxnpicks's Avatar
Originally Posted by Low_e_Red
Or dynamat.
i thought "save a couple of bucks" meant something?
Old Mar 6, 2008 | 05:56 PM
  #44
Low_e_Red's Avatar
Oh... ya... Kinda missed that. Ya...
Old Mar 6, 2008 | 06:42 PM
  #45
SinCityShooter's Avatar
Was it easy to pull the carpet out?
I'd like to dynamat my truck(or cheap stuff) but not sure how the carpets is removed.. in my mustang it was glued to the floor lol.
