Tell me what 2 10 inch subs for this box
Old Feb 11, 2008 | 07:41 PM
shanecaseber's Avatar
What will sound the best used for Rock and some lil bit of rap. I have 5.5 inch's to spear in a stuffed sealed box. I know a lot of you probably have this kind of box. I will want 4 ohm SVC subs so I can run them in parallel to my 2 ohm 600 to 900 watt amp.
Old Feb 11, 2008 | 08:13 PM
mSaLL150's Avatar
Elemental Designs 11kv.2 subwoofers. They come dual voice coil, so get them in dual 2 ohm, wire them each in series to create single 4 ohm loads, then in parallel with each other to get a single 2 ohm load for the amp.
Old Feb 11, 2008 | 08:20 PM
south_ms_sprcru's Avatar
i will definitely agree with Msall on this...thats what Im currently running in my supercrew and I think it sounds great on almost any type of music I play. This is my smallest stereo ever as far as I can remember and I am more than pleased with how it sounds...and this is compared to running 4 sealed Kicker 10s at one point, 3 vented Treo 12s, and dual Infinity 12s sealed at different points throughout my audio life...ha
Old Feb 11, 2008 | 08:23 PM
WHAT ?
Old Feb 11, 2008 | 08:58 PM
Originally Posted by shanecaseber
WHAT ?
No but like this
Old Feb 11, 2008 | 09:23 PM
weazel's Avatar
Registered User
wont those subs hit the floor in a down fire box... i had that issues with my W1's that have excusion near to nothin....
Old Feb 11, 2008 | 10:28 PM
mine dont hit the floor at all in my supercrewsound box, there isnt much room between the sub and the floor at full excursion but they dont hit, that was something i was extremely worried about at first b/c i had never had a downfire box before...but so far ive not had any issues
Old Feb 13, 2008 | 12:26 AM
Ok I am going to go with 2. 10 inch 2 ohm Elemental Designs 11kv.2 subwoofers wired to make a 2 ohm load now some new Q? should I stuff the chambers with polly fill and whats a break in time and how to go about it thanks for all the help
Old Feb 13, 2008 | 12:58 AM
mSaLL150's Avatar
you wont need poly pill, those drivers are designed for small enclosures. Break in shouldn't matter too much, just be careful with your gains and let 'em rip!
Make sure to order straight from ED. They are only 90 bucks each and come with a 2 year warranty.
Old Feb 13, 2008 | 05:04 PM
On the way right from them! Thanks for hooking me up!
