BEST subwoofer list please!
What is the BEST single sub to put with my amp. I have a Sony Xplod amp that is 1200 peak and 500x1 RMS 4 ohm. I was looking at the JL 10w7 or 12w7, but is there a better bang for the buck? Kicker L7 series??? $800 is a lot for ONE sub! I have 2 10" sony xplod's right now but they were cheap and don't quite hit like I want. I am trying to get a lot of bass and am willing to shell out some decent money on the sub this summer when I am working full time. Thanks guys!
Oh I would like a 10", but I know the 12" will give a lot more bass right? I am pretty amateur when it comes to auido, but I did all of the wiring and custom box building in my gallery and it works well. Thanks again!
best sub for the money? IMHO, Fi Car Audio Q. if only i could fit those under my seat
https://ssl.perfora.net/www.ficaraud...iew.shopscript
way cheaper then a W7 and will outperform it by a mile.
Go check out realmofexcursion.com they did a 12" subwoofer challenge comparing all the best 12" subs out there. Fi subs dominated the competition, and the W7 was outperformed by multiple subs that cost much less then it.
I am going to use my existing box with the sub. My box is exactly the way I want it now, so I am going to plexiglass where the front sub is and put the new sub where the back sub is
Originally Posted by anaheim_drew
I would say get a new amp first.......... then new subs
I will have to see the exact cubic ft I built it for but I think it was around 2.3 or something for the both 10's. I'll have to work it out I can always build a new one that isn't an issue. I can design and build something to fit a 10 or 12" sub's specs. I was just saying I like having my sub setup where it is and I'll modify it to fit the sub's specs.
Originally Posted by esf
I second Memphis. I have two M3s and love them. But you're going to be hard pressed to find a good sub/amp combo for under $600. Maybe eBay. If I remember right, my amp alone was $600.
My other question is how big will the difference be over the 10" sony xplods? They have 280rms to each i believe and the memphis will be 1000rms into one sub. I am assuming the memphis will kick *** over the sony system. Is it worth the $1000 is my question?
Also do I want a 2 ohm or 4 ohm amp that is 1000w rms?
ok assuming $400 for a mojo 12" Then I will need a 1000w rms amp for under $600 max. Thanks guys! Where should I buy the memphis sub?
My other question is how big will the difference be over the 10" sony xplods? They have 280rms to each i believe and the memphis will be 1000rms into one sub. I am assuming the memphis will kick *** over the sony system. Is it worth the $1000 is my question?Also do I want a 2 ohm or 4 ohm amp that is 1000w rms?
I would say no considering the other sub amp combos available for $1k
What combo would you get for some serious bass for $800-1000? Thanks for all the input guys!
Based on your box and the available air space, IDMAX would be my sub..
