Why move the jack?
Old Dec 28, 2007 | 02:54 AM
azmidget91's Avatar
Originally Posted by alomar
Just ditch the jack! ^ made a custom box for my 2 10's and currently since the box was installed a couple months or so ago.....my jack just rolls around in the bed
took me a while to figure that ^ meant you were refering to me making your box
btw my jack rolls around in my bed too
btw here is my old box (its for sale make a reasonable offer)
Old Dec 28, 2007 | 09:38 AM
Devildog101's Avatar
Originally Posted by azmidget91
i looked up th jl stealth boxes for the new f150's and they dont require moving the jack.......
http://mobile.jlaudio.com/products_s...hp?fit_id=1512
JL makes three different stealth boxes for the newer body style F-150's. 2 out of the 3 require you to remove the jack. They make a ported for the supercab and a ported for the supercrew. The sealed version fits both.
Read again...
http://mobile.jlaudio.com/products_s...hp?fit_id=1514
http://mobile.jlaudio.com/products_s...hp?fit_id=1567
Old Dec 28, 2007 | 09:49 AM
azmidget91's Avatar
Read again...
yeah it was late last night and i didnt read any of it i just assumed since it didnt go under the passenger side seat(in which i just noticed it does a little bit) then you wouldnt need to move the jack but anyways with that box im sure you could modify the jack bracket to still fit
Old Dec 28, 2007 | 09:52 AM
306stang's Avatar
az midget - what body style is that box made for
ok somebody answer me this. i want to build a box for a single ten under my seat. sub is a kicker cvr.
i've read that some people build a box tuned for "x" amount of hertz or whatever. or they build a box tuned for whatever.
can i simply take measurements and make it fit or do i need to worry that much about the sound?
Old Dec 28, 2007 | 09:58 AM
Jditta's Avatar
You need to worry about the sound. Just building a box to fit the speaker and fit under the seat isn't going to get the speakers max(or what you want out of it sound wise) potential. That's probably why audio shops charge out the *** for custom made boxes
Old Dec 28, 2007 | 10:10 AM
306stang's Avatar
that's kinda what i thought. that's why i didn't want to just jump into it and put on together.
but i'm not paying a 200+ for a box that requires less than $40 of mdf
Old Dec 28, 2007 | 10:12 AM
Jditta's Avatar
I don't blame you, mine was 275. Just search around the speakers section and you'll get the info you need to tackle your own box.
Old Dec 28, 2007 | 11:56 AM
OP see my original reply, just put the jack inside the rim of the spare tire and remount it under the truck
So i answered your question, then jacked your thread
Old Dec 31, 2007 | 10:59 AM
D1A10361's Avatar
Good point!
Thanks for the tip on the JL that fits under one side, Devildog. I only need one 10 at most, so that smaller box should do the trick.
For the record, I was buidling and porting boxes before most of you could drive, I'm just old and married now and don't need to shake the bolts loose. My crappy 5.4 will do that on it's own!
Thanks again,
--David
Old Dec 31, 2007 | 11:30 AM
Originally Posted by D1A10361
Good point!
Thanks for the tip on the JL that fits under one side, Devildog. I only need one 10 at most, so that smaller box should do the trick.--David
Hey your welcome. Just remeber that the JL box that fits just under the drivers side is a sealed enclosure. The others are ported, thats why they take up most of the underneath.
Once you get it and install it, take some pics, and let everyone know what you think.
Good luck,
Devildog101
Old Jan 3, 2008 | 01:15 AM
benkr16's Avatar
i have some pics in my gallery of the q logic box that holds one ten sub. i dont know what it sounds like, as i haven't hooked it up yet. from what i understand, it sounds pretty good for a prefab box. i am getting to old and can't afford to blow my ear drums out know.
Old Jan 3, 2008 | 01:35 AM
azmidget91's Avatar
97-03/04heritage f150 regular cab
