JL Audio
Old Nov 8, 2007 | 01:09 PM
squirtbottle09's Avatar
JL Audio
I have a 2004 F150 Supercrew. I want a JL Audio 10w6v2 to be mounted underneath my rear seat. From the research I have done, I need to lift the rear seat with a LMI lift. Then I should have enough room to mount the sub. Then comes the next problem. Where to mount the amps? I already have eclispe 5x7s and a 400.4 kicker amp for them. I dont know where to mount that either. Also, where can I get a box that is designed for the rear seat after it has been lifted?
Old Nov 8, 2007 | 03:31 PM
dconder's Avatar
You will most likely have to make or have a custom box made for those subs. Mounting depth is right about the max you can fit under there, even with a seat lift. As for amp, look in to mounting it on the back wall behind the seat. Lots of pics on here with amps on the back wall.
Old Nov 8, 2007 | 06:04 PM
But how do you make the seats lean foward? They are fixed.
Old Nov 8, 2007 | 06:18 PM
Low_e_Red's Avatar
Ahh... Young Grasshopper there is much to learn..
Near the metal hoops at the bottom of the seatback are clips that hold the seat in place. Run a search for removal pics.
Old Nov 8, 2007 | 10:32 PM
Will do, lol. I see you have a 10w6v2. Did you lift your seat as well? How do you like it. I would have pm'd you, but this forum requires a minimum of 100 posts or 90day membership .
Old Nov 9, 2007 | 12:10 AM
Low_e_Red's Avatar
I actually havent had the time nor the desire to actually build a box for that truck. I had one built for my old truck but now I am looking to sell that sub/spk setup. Will build one the second i get my new. And yes i need a lift.
Old Nov 9, 2007 | 05:27 PM
How much are you wanting for the sub/amp? PM me the price please.
Old Nov 13, 2007 | 02:11 PM
jalichoacan's Avatar
how do i see ur gallery??
im doing this setup as well!
Old Nov 13, 2007 | 04:26 PM
guitarman502's Avatar
the little camera up in the header of his post by what type of truck it tells he has... (how to see his gallery)
Old Nov 15, 2007 | 11:59 PM
thanks!!
Old Nov 16, 2007 | 07:44 PM
goodwood's Avatar
trying to do the same with the same speakers. Anyone done it the Houston area?
Old Nov 17, 2007 | 01:40 AM
Low_e_Red's Avatar
With what spks? Or am i just plain gone...
Old Nov 19, 2007 | 10:47 PM
I am in the houston area. But have not done it yet though. lol.
Old Nov 20, 2007 | 02:59 AM
goodwood's Avatar
Same ones as the title 10w6v2s. I've read the seats require a lift. But I need a good looking box and also someone who knows how to install amps neatly. I know that goes without saying but the level of quality and expertise is not always the same with all the shops.
Old Nov 24, 2007 | 08:19 PM
05_F150's Avatar
Why the 10w6?? save urself from the seat lift and get the JL stealth box (10w3) with the JL 500.1 amp
