2 Ohm and 4 Ohm on one 5ch amp
5 channel amp...
Originally Posted by TRUEBLUE2004
Yep Even though the amp is 5 channel It's actually a 4 ch and a mono just all built into one. Most are class A/B on the 4 ch and class D on the mono.
What kind of 5 channel amp is it? I know I had a 5 channel class T alpine that wouldnt let you do that. I did it anyways and it clipped rather often and went into protection a few times.
The amp is a Blaupunkt GTA 5350. The specs in the manual give RMS power numbers for 4 Ohm and for 2 Ohm for all channels. That's why I wondered if you could take those specs for 4 channels on 4 Ohms and the 5th channel on 2 Ohms.
This site gives the numbers for 4 Ohms as I see it listed in my paper manual but doesn't list the 2 Ohm settings:
http://www.blaupunkt.com/au/7607792040_main.asp
