Infinity speakers
Old Jun 26, 2007 | 10:59 PM
mgkaotic's Avatar
Infinity speakers
Im looking into upgrading my speakers and Im strongly considering Infinity Kappa 682.7CF for my 03 Screw. What Amp would you guys recommend to power these speakers up front and the rear. These are the specs but I dont know what to look for in an Amp.
Specifications
* Power Handling, RMS: 100 Watts
* Power Handling, Peak: 300 Watts
* Sensitivity: 94dB
* Frequency Response: 40Hz - 25kHz
* Mounting Depth: 2-1/4"
* Impedance: 2 Ohms
Old Jun 26, 2007 | 11:22 PM
TRUEBLUE2004's Avatar
Just keep in mind that they are 2 ohm speakes and to match the power of the speakers with the 2 ohm rating. I believe infinity makes an amp that would work pretty good w/ them but I don't know alot about them.
I have a fosgate 60x4 amp that I belive is 90x4 @2 ohms. I got it at best buy. They are selling last years amps at very good price ($119) if you can still find one. They also have a 2 year warenty if you use a fosgate amp wiring kit.
My bad it's 110x4 @ 2ohms. model p450.4
Old Jun 26, 2007 | 11:45 PM
mgkaotic's Avatar
Oh ok I really didnt know what ohms were, and I was confused as to each speaker needed 100w or if that was for both lol.
Old Jun 27, 2007 | 08:57 AM
ohm are resistance. You don't have to put 100 watts to them it's just the most you can safely.
Old Jun 27, 2007 | 01:42 PM
torqueaholic's Avatar
For best performance get an amplifier that puts out a true 400 to 800 watts per channel.
For good performance, go for about 200 watts per channel.
For average performance, go for about 100 watts per channel.
Old Jun 27, 2007 | 01:55 PM
why would you run a 400-800 watt rms amp to a pair of speakers rated at 100. Seems like a waste of money to me and that you're asking for trouble and blowing the speakers.
Old Jun 27, 2007 | 02:36 PM
dconder's Avatar
Huh
Dynamic headroom is a good thing but, this is a little over the top for a pair of Infinity speakers. In the hands of most users, these speakers would go poof pretty quickly.
Old Jul 7, 2007 | 11:35 PM
mgkaotic's Avatar
I bought the Infinity amp rated at 90wx4, so that should do the trick, just waiting for delivery on the speakers.
Old Jul 10, 2007 | 01:23 AM
snake777's Avatar
Let us know how it turns out after the install. I'm doing pretty much the same thing, 4 INFINITY KAPPA 682.7CF with a MRP-F450 ALPINE 4 CHANNEL amp. Probably gonna use some dynamat in the doors too. Will post up results after install.
Old Jul 10, 2007 | 02:18 AM
BestNTx's Avatar
Haha good god man, thats like cutting a steak with a chainsaw.
Old Jul 10, 2007 | 12:14 PM
APT's Avatar
APT
Power has nothing to do with performance. Most people will use less than 1-watt for every day listening.
Old Jul 10, 2007 | 05:19 PM
You are very correct.
However, others may not know that listening at 1 watt average with a music crest factor of 20 dB is 100 watts peak without clipping. OK, only audiophile music has a crest factor of 20dB. Most run of the mill top 20 and rap has a crest factor of 12 dB or worse.
So that is why I said for "average" performance, go for the 100 watt/ch amp. "Average" should be good enough for the everyday BestBuy or Circuit City consumer, not an enthusiast.
Old Jul 10, 2007 | 09:13 PM
APT's Avatar
APT
Okay, but if person A uses speakers with 96db/w efficiency with 50w availible and person B has 87dB/w with 200w availible, person A's will be louder @ peak and use less power @ normal levels. Also, going from a 100w amp to 400w amp only gains you 6dB peak, and most people don't listen to music in vehicles anywhere close to peak power or speaker levels, whatever the limits are for their system.
My point above was that power is only one part of designing a good sounding system.
Old Jul 17, 2007 | 04:12 PM
snake777's Avatar
Well got this all put in and it sounds great! Needed some help with the amp install so I took it to Earmark. They did a great job. This set-up is loud and clean. At just half volume it will make your ears bleed and there is zero distortion.
Obviously night and day difference compared to stock. I might complete the system later on with a 10" sub. Folks at Earmark said I wouldn't even need another amp.
Old Jul 24, 2007 | 01:30 AM
ssj4shane's Avatar
i have infinity
i like them because you can get them cheap on ebay n...
But the mid base sucks
gota have a sub
but if you mat your doors or make enclosers it will be ok
