Styxnpicks install progress thread
Old May 10, 2007 | 09:40 AM
  #31
Impact9's Avatar
Got any pics you can share and is red out of the color spectrum? I figured you'd go with a red trim and red carpet inside the box. With the smoked plexi it would look pretty cool, if I got your setup imagined right.
Old May 10, 2007 | 09:52 AM
  #32
styxnpicks's Avatar
I'll scan up the doodles
Old May 10, 2007 | 10:15 AM
  #33
styxnpicks's Avatar
ok here are the sketches:
Old May 10, 2007 | 10:41 AM
  #34
Impact9's Avatar
if that's your planned color scheme how about adding some LED fans and some cool fan gaurds to help the airflow and design. That design is awesome btw. should like pretty damn impressive when done.
Old May 10, 2007 | 12:16 PM
  #35
styxnpicks's Avatar
Led fans and grills are for computers
I was going to show off the crossovers and distro block but I think that would be tacky
I want something simple, clean and elegant, but still shows off the equipment, much like the cars in the car audio mags.... oh ya its gotta be stealth too
Old May 10, 2007 | 12:35 PM
  #36
TBDAugs's Avatar
Seas large format tweets
hey styx
Do you plan on keeping those Seas tweets behind the OEM speaker grill?
RibbonAugs
Old May 10, 2007 | 12:38 PM
  #37
styxnpicks's Avatar
Originally Posted by TBDAugs
hey styx
RibbonAugs
unfortunatly yes.
Old May 10, 2007 | 12:51 PM
  #38
TBDAugs's Avatar
Yeah I was looking seriously at those...still am, looking at that 85mm hole it needs for the mount gave me pause.
Want'm bad. Looking forward to your install.
You're aware of the fragile terminal posts on these aren't you?
DIYAugs
Old May 10, 2007 | 01:12 PM
  #39
styxnpicks's Avatar
DIYAugs
i'll be easy on em, I gotta hack alot to get a 4" wide tweeter and 7" woofer in the doors.... and behind the grill
Old May 10, 2007 | 02:02 PM
  #40
Impact9's Avatar
yea true just a thought since you'll need some air flow in there.Then there is neon and all the blingy crap you could do, but that's not what you're going for. Elegant ehh... Wires hide inside the box coming out through the box to the distro then back inside. Could also recess them and have a plexi/aluminum trim window for them. One under each of the outside amps right for power and left side for ground. That would look nice.
Old May 10, 2007 | 10:24 PM
  #41
Bartak1's Avatar
Thats friggin sweet man.
Old May 10, 2007 | 11:37 PM
  #42
styxnpicks's Avatar
and now that I drew it.... you know I gotta build it right. damnit, looks like I got my work cut out
Old May 12, 2007 | 03:08 AM
  #43
styxnpicks's Avatar
man I'm still trying to figure out how to do those bends on the amp rack. talk about a pain in the ***. I'm also working on modeling the amprack in sketchup and autocad right now
Old May 12, 2007 | 03:50 AM
  #44
Impact9's Avatar
It should be fairly easy. I think if you cut the end caps to shape and inner supports the exact same size you'll have the ground work for the overall shape. Then you'll just need to cut the long panels with angled edges. Buy a angle finder, long straight edge ruler, and a good heavy circular saw.
For me a Pencil and draft paper with about 4 dr. peppers and a pile of scrape wood and I'm good to go.
Old May 12, 2007 | 04:04 AM
  #45
styxnpicks's Avatar
yo impact said radius bends not miter corners. I mght just mitering it since bending wood is aove my level of skill.
