Sub in center console?????
Old Apr 16, 2007 | 10:17 PM
bigrook99's Avatar
Has anyone done this? Seen this? Heard of this??
I got the large center console between my 2 front seats (thats usually where they are huh )
Oh yea, I got a 03 f150 Lariat Screw
Old Apr 16, 2007 | 11:33 PM
bigrook99's Avatar
Found this:
http://www.woofersetc.com/index.cfm?...TOKEN=72617321
WOW. Has anyone made their own "custom" style box for the center console?
Old Apr 17, 2007 | 12:14 AM
Impact9's Avatar
I've seen a few but I don't recall where. Possibly over on sounddomian.com or caraudio.com or here.
Old May 7, 2007 | 09:31 PM
DneelMD's Avatar
Originally Posted by bigrook99
Found this:
I built my own box for a kicker L7 10" and then changed it out for the 8" 4OHM DVC that I have in now. It's MDF, 0.35 cubic feet, and fits inside the existing console in my 01 Extended cab. I was and still am too cheap to pick up a $400 JL Audio STealthbox 10" setup. Mine is carpeted and recessed a little bit so I have not lost all storage space, just most of it. I would recommend reinforcing with padding/filler of some sort the sides of the console as they flutter a little bit around 60Hz and below because of all the air movement. Also, you have to cut out the carpet below the console. This makes it much louder and helps cool the sub. After all, who's going to see it?
Old May 7, 2007 | 09:33 PM
DneelMD's Avatar
Correction: $550 + for the JL 10". By the way, the Slobaric 8" L7 plays louder than the JL 10 W0 in their box too.
Old May 7, 2007 | 09:50 PM
150Lariat2000's Avatar
Do u have pictures of urs????
Old May 8, 2007 | 08:10 PM
Anarchy_Customs's Avatar
I built this for an 06 Screw:
Old May 9, 2007 | 12:18 AM
03fx4F150's Avatar
I am in the process of designing a subbox that splits my bench seat so I can fit some 15s and keep the seats.
Old May 9, 2007 | 12:52 AM
cakeeater2's Avatar
i have 2 jl10wo's layin roun my shop and would like to squeeze at least 1 into my 01 supercab, any ideas?
Old May 13, 2007 | 07:40 PM
DneelMD's Avatar
That's awesome.
Old May 13, 2007 | 07:44 PM
DneelMD's Avatar
I'll see if I can find the picture. I basically unscrewed the console and cut-fit pieces of MDF into the original console and cut the bottom out of it for the speaker to feed into the floor. Then I got rid of the heat shield fiber stuff under the carpet I cut out. It makes a huge difference when the speaker fires off the bare metal vs. dense carpet. Anyway, screwed and glued it all together, carpeted the top of the box, and plugged it in. I would suggest reinforcing the sides of the console as they wabble/waffle/rattle a bit when the sub hits. I guess the air buffets back up in there and causes that. I also hid a screw under my cup holders from the cup holder bottom into the top of the console so they don't rattle either. It's counter sunk, fits right in, and you can't tell it's there unless you're looking for it.
However, I will try to find those old "sub box project" pictures somewhere.
Old Dec 21, 2007 | 09:02 AM
DneelMD's Avatar
prior to the L7 Kicker, I had my round solobaric 10" in a box that I pieced together to match the exact dimensions of the original black plastic console liner. Also, my dad's 97 automatic f150 has a sub in a box on the floorboard in the middle under the a/c controls that butts up to the front of the bench seat. It looks really nice, almost normal if I didn't know better.
Old Dec 21, 2007 | 06:03 PM
DRJ's Avatar
DRJ
My center console has been out of my truck for about a month now.. I never got around to building the console I'll get to it eventually
Old Dec 21, 2007 | 06:07 PM
Jditta's Avatar
They don't make round solobarics.
Old Dec 21, 2007 | 06:15 PM
azmidget91's Avatar
lol sounds like me except mine has been out for about 2 years now but seriously im going to build mine soon and finally figured out exactly how im doing it, ive gone through about 5 designs and trashed one half way done console, btw it will be all fiberglass i wont be using the stock console at all
