what kind of sub box can i put in my 01 supercrew
Old May 20, 2007 | 09:32 AM
Iam4st8's Avatar
patman how'd you get those two captain chars in the back? did you buy them? if so how much
Old May 20, 2007 | 02:04 PM
one of them is factory installed, the other is one i bought out of a guy's screw that he was parting out. 300 shipped i believe is what i paid, coming from cali to tx... Anyways you drill one hole out for the seat bracket, and everything else converts over.
Well on my 03 thats true. I had someone i was talking to a while back i believe his truck was an 01 that he didnt have the seatbelt clip mounting hole in the floor already.
Old May 22, 2007 | 02:01 AM
south_ms_sprcru's Avatar
im gonna second checking out supercrewsound.com, those guys are great and the customer service is awesome. i have dealt with them on several occasions and bought two boxes from them, one of which is in my screw now and i couldnt be happier with it. very solid made and the local shops couldnt believe how little i paid for it. they all wanted 75-125 more to build it for me
Old Jun 14, 2007 | 05:32 PM
wookie13's Avatar
mark could u send me the dimentions for ur box i would love to have that setup in my 02!!
Old Jun 21, 2007 | 07:18 PM
mark03screw's Avatar
I don't have the plans anymore, but you can just pop off the back panel and measure yourself. I took the smallest width which was at the top, subtracted a 1/4 inch for good luck, then i measured the height at the back against the frame, and how far i could stick out at the top and bottom. Did a little trig to figure my angles and off i went. I had to inset my sub so it wouldn't hit the back of my seat. It sounds great thou, better with the seat up than down. The person sitting there will get quite the massage, but i havent had any complaints yet. Good luck!
Old Jun 21, 2007 | 10:56 PM
attitude's Avatar
So Mark, You think I can run my Kicker L7 8" in a box just like that. Cause that is what I want right there. Was just concerned it wouldn't be deep enough to clear the magnet.
Shane
Old Jun 22, 2007 | 01:29 AM
Shane
Aye, my sub was 4-15/16" mounting depth and i was using 3/4" MDF. I'd go with 5/8" if i were you cause it'll gain you an extra 1/4". Needless to say i put my sub as low as i could in the box and i still had to rip off the rubber thing that sits around the magnet (i think its just for looks anyways) and i still had to grind a little into the box to make it fit. But other than that it fits fine. Just be sure to find out the mounting depth of your sub and see if it'll fit in your design of the box. I had to remember how to do trig all over again cause i hadnt used it in years. Good luck!
Old Jun 22, 2007 | 08:22 AM
attitude's Avatar
Mounting depth is 4.8" according to the spec sheet.
Shane
