JL vs others
JL vs others
I'm about to build a dual 8W3V2 box. I know that the JL's are pricy, but I need two 125W 8's that are shallow and that can be wired as a 4 Ohm circuit. So my options are:
single-coil or dual-coil 2 Ohm
single-coil or dual-coil 8 Ohm
dual-coil 4 Ohm
I found RF and Kickers that foot the bill, I'm just curious as to what you guys think. JL is almost 2x the price.
I'm also concerned with excursion as this will be a down-firing box and I don't want the speakers slamming into the floor. RF P1S88 are spec'd at 1.6" and the JL 8W3V2 are .39". But then JL spec's theirs as "one-way", so does that mean that RF's are really 0.8" one-way?
The more I read the more I don't know what to do. So what the heck should I buy? Bring on the opions, please.
dual-coil 4 Ohm
Jlaudio
dual-coil 4 Ohm
dual-coil 4 Ohm
Hi i am looking at jlaudio also but i don´t know i those regular sub will lift the seat in the truck i like the W7 series also and cheeking at KICKER COMP VT 07 CVT 102 it a shallow sub i don´t know if jl makes shallow sub.
As far as I can tell, nothing bigger than the 8W3 series will fit without a seat lift.
I'm going with two Polk MM2084 anyway. 4.25" top mount, 200W RMS, very tight excursion, 1/2 the $.
Jlaudio
