04+ Guys who've used acoustic dampening..
I plan on doing all 4 doors, back wall, all of floorboard, and "b" & "c" pillars.
to remove front doors
1) remove front speakers
2) remove switch panels
3) remove 2 6mm screws from bottom of door panel
4) remove bottom 2 front speaker capture nuts from sheet metal
5) remove 10mm bolt behind switch panel
6) pull up and out on door panel
7) remove handle by pressing 2clips together, and pull handle toward "interior" of truck then out back of door panel.
Originally Posted by SSpiro
My eDead came in today, and I'd like to do it this weekend.
Did you do the entire front doors, or just behind the speakers??
If the whole door, how the eff does the door cover come off?
I posted a detailed explanation on door panel removal a few months back.
https://www.f150online.com/forums/sh...63&postcount=3
I done inside of door as much as possible, install a 10 x 12 piece of E4 foam behide speaker hole, made a panel of cover the big hole in door, then covered with Edead, then covered with E4 foam... yes, the door panel will be a bear the get back on...
same on back doors
Pics in my gallery...
still have to do the back wall, I already have the Edead setting here..I myself am not planning on doing the roof and floor...
same on back doors
Originally Posted by styxnpicks
I would do the roof before I did the floor if I had to do it again. I also recomend using expanding foam in the c pillars and back wall cavities while the truck is gutted
Is that REAR FILL I see in those rear doors, from the KING OF REAR FILL SUCKS MAN...
I couldn't resist....
I would doo the roof before i did the back wall... makes a HUGE difference when its raining.... of course I don't think you have enuff to do three layers like I did
lol you should see it now.... nothing but sounddeadening there now. the door you don't see doesn't have a speaker in it and the fade was all the way to the front anyway
I think i've got 30sf left from the doors...
I see now, at quick glance, the plug looked like a tweeter...
then I bought another 100 sq ft and used about 10 on the c pillars and what I wasn't able to get on the back wall twice. then I used 15 sq ft in each rear door and about 30 sq ft in each front
