i need help!!!!!!
Old Jan 3, 2007 | 08:56 PM
06 f150 WHITE's Avatar
i need help!!!!!!
I was woundering if i can fit 12" subs under my new o6 f150 without lifting the back seats and also where would i put the power cap/amp?
Old Jan 3, 2007 | 09:14 PM
Bartak1's Avatar
Depends on the sub.
Smitty and Doug talked like they might be able to squeeze a pair of 12" IDQs under the back seat without a lift. Youll need to find something with a shallow mounting depth (probably less than 5.5 or so, not real sure) and something that requires very little airspace.
As for the amps, on the back wall behind the seat back. The cap can go under the tires J/K, there is plenty of room back there for a cap and a few amps.
Old Jan 3, 2007 | 09:31 PM
TNoff's Avatar
That's good to know for future reference.
Old Jan 4, 2007 | 09:14 AM
dconder's Avatar
I am still planning on getting ahold of a 12" Image Dynamics IDQ and giving it a try. It has a mounting depth of 5 3/4".
Old Jan 4, 2007 | 11:31 AM
brypink2's Avatar
You'll be able to do it. Just cut a hole out on top and put a plate up there like mine. I bet it would work.
Also, those prefab boxes fit easy, they have like 5.5"+. When you build your box, go in there and add a 1/4" here and there...then cram that thing in under the seat...I'm sure you will get the mounting depth you need.
Old Jan 5, 2007 | 03:03 AM
Impact9's Avatar
Talking about this one?
http://cgi.ebay.com/12-IDQ-12D4-Imag...em170057092486
Old Jan 5, 2007 | 09:25 AM
dconder's Avatar
Originally Posted by Impact9
Yep, that's the one. Even the box I have now could probably be modded to work. It has a mounting depth just over 5" with a 3/4" spacer on the bottom. Cut a hole in the spacer and put a thin piece of steel over it with some damping on it and you have around 6" of depth.
Old Jan 5, 2007 | 10:15 AM
Impact9's Avatar
That is very tempting to attempt. The power level is about right, mounting depth near perfect, and I wouldn't need to do a seat lift. There any other contenders for shallow 12's?
