upfiring 12s?
upfiring 12s?
If I were to build a box with 2 12s firing up at the rear seat, would it damage the subs.
got the idea from this, it says it is for '04-up.
http://woofersetc.com/index.cfm?fuse...roduct_ID=3688
Since your making your own all you have to do is design it to your specs...it depends on the subs, but you will probably have to lift the back seat so you can get your mounting depth, plus room between the box and seat bottom so the sub doesnt hit...
Originally Posted by jmt0645
but if I were to buy the box, what would it do to the subs, cause them to blow, what?
Ok, got curious so I called 'em and they said there is 1/2 inch between top of box and bottom of seat for sub excursion, and it also doesn't stick out from in front of the seat any. so for those who want 12's in their f150s, this doesn't sound all that bad.
Also, if that box is 6" overall depth made out of 5/8" mdf that in only 5 3/8" depth which means they had to make a cutout under the holes for more depth. And, I do not think 6" will fit all the way up under the rear of the seat. All boxes I have seen are wedge shaped to fit the contour of the seat bottom. That is a lot of money to be wrong. How's there return policy?
Depending on how much xmax your subs have, it could be bad.
The underside of those seats just have cloth on them and no braces, dont then? That should give you some more space, your subs will probably will kiss the bottom of your seat though.
As long as they are really slamming into there they should be 'ok'. It the bottom of the seat is actually stopping them from full excursion that could possibly do some surround or maybe cone damage.
Just try it, and if its very bad, stick some grills on there then slam your seats down lol
