Box plays too low
Old Dec 1, 2006 | 10:40 AM
styxnpicks's Avatar
your looking for midbass, save you money buying another sub untill you upgrade your frontstage
Old Dec 9, 2006 | 08:44 PM
Riken's Avatar
Originally Posted by sick f1
if u go with a smaller sub, it will hit quicker because the cone does not travel as far as it would with a lets say 12 or 15". the deeper the bass u want the larger diameter sub u want.
the smaller the sub the quicker/more clear of a hit, the bigger the sub, the longer it takes to reach its note, but the deeper it will hit,
this is absolutely incorrect. that is one of the biggest misconceptions in car audio.
the speed of a subwoofer is affected by: type of driver, enclosure type/volume, and amplifier type/power. do some reading on ECA and you will read IDQ15's will play just as quick with excellent SQ as compared to others 8's or 10's for example.
if you think your sub plays too low, you have achieved what 90% of everyone out there are trying to achieve. i'm going with 15's to get the low notes. a good front stage will determine your presence and speed.
you should try more power to that same sub and you might be amazed at the improved control. i've had ~750 wrms to a single 10w6 in 1 cuft sealed and it hit very low and fast, even though jl doesn't recommend a box that big.
