No sound from my speakers...
Old Nov 23, 2006 | 10:32 AM
smann's Avatar
I have a 1995 F150 and I get no soudn from my speakers. The radio is a Panasonic CD with removeable face. a guy at Circuit City said one of the speakers was bad. Does this sound accurate? Any suggestions are appreciated.
Old Nov 23, 2006 | 10:47 AM
Josh98xlt's Avatar
If you are not getting anysound at all,it may be something more than a bad speaker. Try reseting the head unit first,then if still nothing take a 9v battery and touch them to the speaker wires and you should hear a click or pop when you do, if you dont you have a bad speaker. Do this to all spoeakers to teast.NEVER trust circuit city, always tring to make a buck
Old Dec 18, 2006 | 01:19 PM
smann's Avatar
I tested the speakers...
with the battery and they checkout fine. does this mean the unit is bad?
Old Dec 18, 2006 | 06:06 PM
Bartak1's Avatar
Do you have a multi meter? If so, put in on the lowest AC Volt setting you can, and run some music through the cd player at a higher volume. You should get a reading on the meter. If not, there is either faulty wiring, or the internal amp might have taken a dump. I
Its not a setting on the HU that is set wrong is it?
