bry.. I need comps
Old Nov 3, 2006 | 01:34 AM
styxnpicks's Avatar
bry.. I need comps
dude I stil have no clue wha to get as far as comps. I'm still leaning towards a 3 way with a 7 inch woofer.... in the door (im that good). what do you recommend bry? I have a 250x2 @2 ohms ready now but I really wanted to go active with about 100x6 @4 ohm. but I'm having a hard time finding that last xs900.4
Old Nov 3, 2006 | 03:30 AM
styxnpicks's Avatar
nevermind D971 it is unless someone recomends anything better
Old Nov 3, 2006 | 09:32 PM
brypink2's Avatar
Well, there you go!!! All done. But, if those are 2 ways...I wouldn't rule out the PowerLines CS set.
Old Nov 3, 2006 | 11:09 PM
styxnpicks's Avatar
it really all comes down to whats the better bang for the buck. I was going to go 3-way till I really looked at the door and was like WTF I can cram a 7" woofer here
Old Nov 3, 2006 | 11:26 PM
brypink2's Avatar
The PowerLines are a 7" mid (6.9"). It's based off one of their subwoofers. But, I definately can understand "best bang for the buck" concept. Those D971s do look good.
Old Nov 3, 2006 | 11:30 PM
styxnpicks's Avatar
well it was either between rainbow, diamond or seas. whatever has the best midbass will win at this point
Old Nov 4, 2006 | 12:45 AM
brypink2's Avatar
I'm just really impressed with the PowerLines.
Old Nov 6, 2006 | 05:25 AM
styxnpicks's Avatar
so what would you pick between the powerlines, D971, and maybe something like the seas lotus, i'm probably going to go 2 way since I can get a 7 incher in the door..... plus then I don't have to buy another amp and go active
Old Nov 6, 2006 | 01:00 PM
brypink2's Avatar
I really dig the powerlines...but, those D9s are pretty efficient. I haven't heard them. How much are they? The PowerLines are $950.
PM sent also.
Old Nov 6, 2006 | 09:04 PM
Bartak1's Avatar
Styx, are you still going to go active, even if you get something like the PL's or D9's?
If your thinking that, why not just get some nice DIY (not the brand DIY) mids and tweets, instead of of buying a whole comp set and not using the crossovers, which can be a decent chunk of the money you spend on the comp set. They way I see it is you could just get a mid and tweet equal to those in a comp set for cheaper because you wouldnt have the added cost of a xover, or else spend the money you save from not getting a crossover on some nicer mids/tweets? Just seems like wasted money to me if you buy a whole set and throw out the xovers when you could have used that money on some separate mids and tweets.
Of course not saying you can run a comp set active...just seems like wasted money, not to mention the crossover that comes with them is made to work those drivers to their fullest potential, so why not use them?
Im not trying to be smart or tell you what to do, I know you are perfeclty capably of making up your own mind and you sure know what your are doing, but I just thought Id throw that in.... :shrugs:
If you arent running active then feel free to cyberslap me
Old Nov 6, 2006 | 11:20 PM
styxnpicks's Avatar
i'm not running active. I can't find another amp to do it
Old Nov 6, 2006 | 11:56 PM
BestNTx's Avatar
amature question here but what exactly does "running active" mean?
Old Nov 7, 2006 | 12:15 AM
brypink2's Avatar
Basically, you get rid of the passive xovers and use the xovers on the HU or amp. You need an amp (or channel of an amp) for each pair of speakers...i.e., 1 amp for the mids, 1 amp for the tweeters.
You don't have the benefits of the passive xover doing all the work for you...you have to manually set your points and slopes. Gives you more flexibilty in your settings.
Make sense?
Old Nov 7, 2006 | 12:32 AM
styxnpicks's Avatar
plus the amp setup in the bed wll look better with the three amps I got. active would be nice but at this point I just want something besides these stupid stockers. it doesn't matter anyway since I need the bedrug before I do anything else
Old Nov 7, 2006 | 07:09 PM
Bartak1's Avatar
Doh!
