bry.. I need comps
Originally Posted by brypink2
Basically, you get rid of the passive xovers and use the xovers on the HU or amp. You need an amp (or channel of an amp) for each pair of speakers...i.e., 1 amp for the mids, 1 amp for the tweeters.
You don't have the benefits of the passive xover doing all the work for you...you have to manually set your points and slopes. Gives you more flexibilty in your settings.
Make sense?
Make sense?
Originally Posted by BestNTx
Sure does, I think I am going to get some comps up front (im currently running MB Quartz discus coaxls) and i am not pleased with the bass response of them. But i do believe when I get my comps i will run them with a crossover. Is it at all possible to get a good pair of comps that i can crank up and still have good sound quality for around 100 bucks for the pair???
Originally Posted by scsmitty78
Bryan and I both just picked up some Hertz Audio HSK 165 comps for $110 shipped each. He hasnt hooked his up yet but I have mine. They sound pretty damn good. Especially for the price.
He's taking out his Rainbow's to put hertz audio in?
where did you get them from for that price? Also, how did you mount them in your truck? did you have to prefab a mounting plate to fit the woofer into the 5x7 spot? Also are they 5.25 or 6.5's? Did you have to do any cutting?
