radio removal
Old 09-21-2006, 06:18 PM
Clemson Tiger's Avatar
Question radio removal
I am wanting to access the rear of my radio to hook up RCA cables for an amp and sub woofer. How do I remove the radio in a 2004 F-150?
Old 09-21-2006, 07:27 PM
CHIA's Avatar
Not too sure if you will find any RCA inputs back there, you may need some type of wire harness to do that. To get at the head unit, you open the ash tray, and simply pull the centre trim off. It's just stuck on with posts & holes, so with a bit of force, it will come off from the bottom upwards.
I have removed mine many times.....feels a but un-natural at first, like you might break it, but it does come off, and goes back on very easily as well.
Hope that helps,
CHIA
Old 09-21-2006, 08:02 PM
nigdonht's Avatar
You will likely have to buy a line output converter to convert your speaker wires to accept the RCA cables, something like THIS will work.
Old 10-01-2006, 01:22 PM
sprey's Avatar
Old 08-29-2008, 08:59 PM
Grampales's Avatar
Thank you
These pictures were very hepful, i will follow your directions as i need to remove the radio/CD player because there are CDs stuck in the units and I cannot eject them. The player justs continues to say reading disc.
Quick Reply: radio removal
