sub boxes
Old Jun 22, 2006 | 04:17 PM
Zaairman's Avatar
Originally Posted by TXhustla
Ok, could 2 10s be downfire in a single cab? If so is that better than a sealed.........
Yes, but for it to sound the best you need to run it sealed. You don't have enough room to run ported.
Old Jun 23, 2006 | 06:15 PM
TXhustla's Avatar
Would I be able to be heard outside..........
Old Jun 23, 2006 | 09:41 PM
97f250's Avatar
Is this what you want, to be heard outside? If so, remove the passenger side half of the seat, install the following gear and you're set. You only need about 5 1/2 cubic feet of space. You could make the enclosure look like a small picnic table, perhaps.(I may consider this myself as it would be particularly handy for lunchbreak at work) The important thing is, you will be heard.
http://www.partsexpress.com/pe/showd...number=295-469
http://www.crutchfield.com/S-4aVzqH3...0PDX1100&g=120
Old Jun 24, 2006 | 10:43 PM
TXhustla's Avatar
Yeah that is why a system is to be purchased. I just want it to pound the hardest it can without taking/cutting anything out................
Old Jun 29, 2006 | 03:29 AM
RageOfOrder's Avatar
Ported will get you a louder sound, by maybe 3dB or so... If you just want volume, do two subs in a sealed box.
I have a 6.4" deep SPL sub in a ported box in my reg cab. I don't turn it up a lot, but **** it's loud when I do. The box is three feet long because of the port and there is no way in hell I'll be fitting the other identical sub (sitting in the original packaging in my room) into this truck if I want a ported enclosure and full use of my seats....
Also, it doesn't take much "to be heard outside". You can do that with about 380 watts of clean power and a good sub/box combo.
Old Jun 29, 2006 | 02:31 PM
TXhustla's Avatar
Will it be worth it to change to ported? My depth is only 5" so I think I can get both with full use of seats..........
Old Jul 15, 2006 | 01:45 AM
sed2208's Avatar
Originally Posted by roushracin
I dont know about all you guys but I have 2 12' diamond audio subs with two diamond audio 1200 watt amps in a down firing ported box and I know nobody is louder than me with a sealed box. I have a regular cab 04 ford truck
4 m3mojo's by memphis, 4 mmat 1200, sealed box, blew the windows out, right there in jacksonville.. if your not hitting like that, don't say nobody's louder. it will make your heart miss a few beats
Old Jul 15, 2006 | 01:55 AM
sed2208's Avatar
down. sealed
