Replacing stock speakers?
I got an '06 F-150 Texas Edition recently, and the speakers don't provide as much power or punch as I would have hoped. Does replacing the speakers create a significant gain in sound quality? Also, what brand would be recommended?
I also plan on adding a sub sometime in the future.
You can do it, just know where your bar CAN be and mis some notches.
A general rule of thumb:
signal starts at the source, cheap source cheap signal, everything down the line works off of this signal.
speakers are the voice of the system and provide the sound quality(good and bad)
amplifier (or radio power) provides the volume of the system
low bass requires both a sub and amplifier.
decide which one you need and thats where you want to start.
While I understand what RkyMtn is saying, I think its perfectly fine to buy the parts to a system and add on as you go.
But I do think you need to plan out what you want, and get a real good idea of what you want to install (down to the specific amps, speakers, etc). Then you can start figuring out what to buy first.
As has already been said, I would start at the head unit, especially if you plan on running components.
What I would not suggest is buying "temporary" solutions. Dont waste your money buying equipment that is better than stock but wont end up in your final system...
My $.02
My $.02
It all depends on what you want to do. A couple of weeks ago I got a 2006 F150 Supercrew and was very displeased with the sound quality of the head unit. I did a little research and replaced the front speakers with a pair of Memphis audio 5x7's. Much mo better now - a much cleaner sound. The head unit is not the greatest in the world, but the POS Chinese junk $2 throw in factory speakers make the sound 10x worse.
Now if you want power you gotta junk the head unit and throw around some money. Just replacing the factory speakers won't do it.
My System
After buying my new truck,my wallet felt the heat. Here's what I did over a period of three or so months.
I replaced the stock door speakers with 5X7 Pioneer coaxials. Definite improvement. Great little speaker for little money.
Added a Memphis 10 inch sub in an AE enclosure and Memphis amp.
Replaced the HU with a Kenwood. Awesome. Everything came together at that point!
Total cost, including installation: 620 bucks.
The system rocks and sounds wonderful. Really clean.
Good luck!
Good luck!
I would add that in reference to audio, general statements are almost always unreliable. A generalization simply saying aftermarket speakers will be an improvement can be wrong. However, unless you buy those 6000 WATT 5x7s at the fleamarket for $19.99, most any decent aftermarket speakers WILL improve clarity and detail, even with the stock HU. They may not be any louder, but will be "cleaner". There is a difference. But, in my humble opinion, unless someone can be happy with low to mid volume at very average sound quality levels, the stock HU should be canned ASAP, and properly matched speakers, subs, and amps added. There is no other way to get true high quality, high volume sound with the "pop" and "slam" that is present in the real thing. Making it sound like live music should be the objective. I understand that sometimes we can't afford all this at once, but at least plan ahead by buying equipment that will work correctly with future purchases and will give you a system that will do what you want it to.
I agree with all of this so far. I am doing mine piece by piece, and have done headunit and speakers. This made very little difference, but I think my problem is the low end. I'm gonna get an amp soon and a sub to go with it.
--If you know how the music sounds by heart...I mean EVERY NOTE, than listen to see if all the Bass notes from the keyboards, drums, and bass guitar make the speakers give a cracking/static sound. Same for drumset cymbals. If the speakers "crack" at the time those notes are played (at least in my theory, to be proven right or wrong when I get the $$$ for my amp and sub), than you are not getting enough power to the high end beacuse the tweeters are making a futile effort to hit the lows.
BUT REMEMBER... This is all my theory. Those who have done this know better, and I would appriciate it if one of em could inform me as to the relative correctness of my drawn-out theory.
