Component tweeter install- drill into metal panel?
Old Jun 12, 2005 | 06:46 PM
Black Frog's Avatar
I'm getting ready to install a set of Polk MOMO component speakers in the front of a '01 Screw. I've seen many people flush mount tweeters just in front of the door handle in the "soft" area of vinyl.
For those that have done this, did you have to drill into the metal of the door to get deep enough clearance for flush mounting? There's some sort of connector mounted on the door right behind where this soft vinyl area of the door panel is. Did you have to move that connector?
Thanks for any input-
Old Jun 13, 2005 | 12:39 AM
Bartak1's Avatar
Depends how much mounting depth your tweet is man. Mine are right around 1 inch, and they are in my door panels withough hitting the metal behind.
Old Jun 13, 2005 | 12:02 PM
rockafella's Avatar
They won't hit metal in the door panel. But, the problem is, ripping the vinyl when drilling your mounting hole... If you use a hole saw the exact size of your tweeter hole, you risk tearing the vinyl and the flush mount tweeter cup edges might not cover rips and tears caused by drilling. The vinyl pad is plastic melted to the back of the panel, if you pull the door panel you'll see that theres about 3/8" or so of plastic to drill through. You'll have to pull the panel and see if your mounting spot is clear of any wires, the panel dosen't have wires on it, but they do run along the top, bottom, and sides of the door. I set mine in the plastic panel itself. Your going to have to place a pice of wood over the vinyl before you drill to minimize tearing of the vinyl.
Old Jun 14, 2005 | 11:18 AM
Kurt_02F150's Avatar
i mounted my cdt tweets in the sailpanel. i think it helps with imaging. its all personal preference though.
Old Jun 14, 2005 | 12:48 PM
Black Frog's Avatar
Well I think I can get by without going into the metal behind the vinyl area if I reroute the connector and cable mounted on the metal panel. I'm going to precut the soft vinyl with an exacto knife, and then use a hole saw to finish the job.
I'd like to keep the tweets up higher than Rockafella has them if I can- I think it sounds better (to me). I don't think I could flush mount the MOMO tweeters in the sail panel without going into the metal behind the door panel. The MOMO tweets require a 1-3/16" depth to flushmount.
Old Jun 14, 2005 | 01:40 PM
Bartak1's Avatar
Rockafella, whats that switch up at the top of that pic, about right in the middle?
Old Jun 14, 2005 | 02:26 PM
Black Frog's Avatar
That switch is for the adjustable pedal position- I have the same switch.
Old Jun 14, 2005 | 05:35 PM
Rider69's Avatar
when first trying to find the optimum placement for the tweeters, use some double stick tape and try them out in a few different places to see what offers you the best sound.
Old Jun 14, 2005 | 07:34 PM
Bartak1's Avatar
Adjustable Pedals??? Dayum, when did they come out.
Old Jun 15, 2005 | 11:11 AM
rockafella's Avatar
The switch is the adjustable pedals, first avalible in the Harley, I think. Anyway, I wanted my tweets in the sail panels up high myself, but the drivers side sail panel is smaller and mounting it would be more trouble than is worth, so because I have kick panels and those tweeters aim straight at my ears, mounting the other set low wasn't a big deal, still have a great sound stage.
Old Jun 16, 2005 | 12:37 PM
Black Frog's Avatar
Well I got them in without drilling into the metal door panel. It was a tight fit and I had to re-route the connector and cable just behind the soft vinyl area. The cable used to come up over the top of the stock speaker hole, I rerouted it down around the bottom of the speaker hole and drilled in some cable holders to keep it in place.
I traced out my hole on the vinyl and precut the soft stuff with a razor knife. Then used a normal hole saw to make the hole through the panel. No rips or tears. Looks great.
Old Jun 16, 2005 | 01:45 PM
i used cdt cl62 components.
Old Jun 17, 2005 | 11:16 AM
rockafella's Avatar
Good job BLKFROG, post some pics!
Old Jun 18, 2005 | 09:14 AM
Black Frog's Avatar
For the MOMO tweets, I don't think I could've done the sail panel mount without hogging out the metal for clearance. For the flushmounts with the MOMO's they are fairly deep. I'll see if I can get some pics later today....
