Lightning Subwoofers
Old Apr 16, 2005 | 04:11 PM
stevenpeven's Avatar
I want to put some subs in my L that can be heard before my car is seen. I want no more than 2 subs, and I want to mount them in the cab of the truck. Can you recommend any subs and an amp for the subs? Would 2 JL Audio 10W3V2-D4s with a JL Audio 500/1 amp do the trick? Thanks.
Old Apr 16, 2005 | 04:15 PM
Deus's Avatar
Re: Lightning Subwoofers
Old Apr 16, 2005 | 05:32 PM
Any suggestions?
Old Apr 16, 2005 | 06:47 PM
octogon169's Avatar
that set up you listed will rock, but you can probably get a bigger amp like the 1000/1. i don't know what the rated power for those jl subs are, but i would guess that they can handle more than 250 watts a piece. also, key to your sound is going to be the build of the box. make sure you take it to a place that knows what they're doing. i've got two 10's in my L with 1200 watts going to them (phoenix gold xenon subs and amp) and it pounds!
Old Apr 16, 2005 | 08:41 PM
How much did the subs and amp cost you? Did you get a custom box built? How much did that cost?
Old Apr 17, 2005 | 06:34 PM
GA FOO 88's Avatar
If i were you i would just get a top of the line 12 with a mono amp.
$300 price range- orion H2, RE SX, ID Max
$350 - $400 price range - RE XXX, Adire BRAHMA
Well you were looking at around 300 for the two w3v2s, but if you wanted to go with just one 12 any of these would be a good choice. Depending on which one you choose, you will more than likely have to put it in a sealed box though.
Old Apr 17, 2005 | 07:15 PM
Bartak1's Avatar
They XXX and Brahma have a fairly deep mounting depth if I remember right though. Might not be able to fit them in a L.
If you REALLY want to be heard from 5 miles away, your probably going to want someting more than 10's.
Like Ga Foo said, maybe one or a pair of 12's.
IA, RE, Adire, Ascendent audio, soundsplinter...all very good.
Old Apr 17, 2005 | 08:08 PM
octogon169's Avatar
i did get a custom built box. i don't know the itemized cost of my whole system (my brother owns the shop and did the install) but i paid about $4,500 for everything. here's a couple of pics of the box:
Old Apr 17, 2005 | 08:46 PM
Bartak1's Avatar
[QUOTE]Originally posted by octogon169
paid about $4,500 for everything. [/QUOTE
Wow thats a lot of money.
Looks pretty darn nice though.
Old Apr 18, 2005 | 04:50 PM
So, what company makes really hard hitting 12" subs that don't require alot of mounting depth?
Old Apr 18, 2005 | 05:09 PM
YZF-R1's Avatar
Stevenpeven, what type of music do you listen to? It will make a difference in what type of sub will work best.
Octogon169 - NICE set-up!
Old Apr 18, 2005 | 05:57 PM
Pretty much all rap. I know the JL Audio 13W7 hits extremely hard, but I sincerely doubt that it would be able to fit.
Old Apr 18, 2005 | 06:28 PM
octogon169's Avatar
[QUOTE]Originally posted by Bartak1
tell me about it! my brother owns the shop too!!
Old Apr 18, 2005 | 06:31 PM
octogon169's Avatar
in one of the smallest vehicle compartments that you can find (single cab pickup) two 10's will hit HARD. you may not be able to here from ten blocks down, but inside, you won't even be able to tell the difference. i listen to metal and rap, both require a ton of bass, and my two 10's pound. just make sure you have enough power going to them.
Old Apr 18, 2005 | 06:48 PM
Will they hit hard enough that when stopped at a light the cars next to me will hear it?
