I have a 2000 Lightning with a custom box built for behind the seat to hold two 12" sub woofers. What subs should i use since i have soo little air space? and what amp? Any help would be greatly appreciated.
I'm guessing the box will have a somewhat small enclosure space around or under 1 cu ft. I'd recommend Image Dynamics or Elemental Designs. Also... JL audio.
If you're stressed for airspace.. you might look into Boston Acoustic Pro.
Its not the loudest sub on the market but its very accurate and works perfectly in smaller than ideal enclosures.
