Where is my......
Old Apr 21, 2002 | 04:40 AM
SPROCKET_X's Avatar
Where is my......
I'm finaly getting around to changing the fuel filter but I'll need to reset the inertia(SP?) button. I know it's some where by the brake pedal but I don't know what I'm looking for or what it looks like. The only thing I see is a little square box, but I think it's my alarm because it has a bunch(10-15) wires coming out of it.
Any help would be greatly appreciated.
Thanks,
Justin
Old Apr 21, 2002 | 05:08 AM
IzzyEddy's Avatar
Cool
Sprocket_X, I am not sure on the year of your truck but my '87 had it on the firewall behind the clutch/brake area. It would be about 3"x4" in size with a button on the top of it. I think it was a white button too, not sure though, could have been grey. Once you push it back down, everything should be fine. To tell you the truth, I have never even looked for it on my '94 but that is something that I will definitely look into. That is probably where I would start OR it should also be in your manual that comes in the glove compartment of the truck. That would be a definite place to look, it would have to be in there somewhere.
Have Fun & Keep on Truckin'
Dean
Old Apr 21, 2002 | 06:22 AM
PKRWUD's Avatar
Just release the pressure at the schrader valve on the fuel rail. Don't screw with the inertia switch.
Take care,
-Chris
Old Apr 21, 2002 | 09:59 AM
Ford4ever's Avatar
The Schrader valve is the easiest as previosly stated, but for future reference i believe your inertia switch is up under the dash by the passeger side kick panel, right up behing the glovebox.
-Jon
Old Apr 21, 2002 | 10:08 AM
Macgyver's Avatar
hummmmmm mines right behind the brake pedal ??
Old Apr 21, 2002 | 12:40 PM
Donate54's Avatar
Take care,
-Chris
is ti bad to turn off the inertia switch? when i went to install my fuel pressure gauge sender i did both, i pushed the inertia switch AND release the fuel rail pressure with the schrader valve. just wondering...
Old Apr 21, 2002 | 01:04 PM
PKRWUD's Avatar
No, it's not bad, it's just not necessary.
Take care,
-Chris
Old Apr 21, 2002 | 02:08 PM
SPROCKET_X's Avatar
I'm going to sound like a ding bat when I ask this but here it goes...where's my schrader valve? Oh ya and where do babies come from?
Old Apr 21, 2002 | 02:44 PM
Ford4Fun's Avatar
the shrader valve is on your fuel rail, it will look like a tire valve.
....and babies....ask your parents,they know.
Old Apr 21, 2002 | 02:49 PM
SPROCKET_X's Avatar
I've been wondering what that thing was...thanks
Old Apr 22, 2002 | 01:23 AM
PKRWUD's Avatar
SPROCKET-
Just to make sure you're looking at the right item, on the 4.9L, it's in the very back of the engine compartment. In fact, I don't think I've ever actually seen mine, I just feel for it.
Take care,
-Chris
Old Apr 22, 2002 | 01:35 AM
SPROCKET_X's Avatar
ya..I saw it when I put in my new PCV the other day...but I didn't know how to get to it so I just popped up the inertia button behind the passenger side kick panel and started the truck until it died(about 5 seconds) then replaced the fuel filter and pushed the button back down cleaned up and the truck started with no hesitation. It ran kinda crapy for a few blocks but I geuss that it just had to build up more pressure cuz it runs fine now...actualy I feel a difference in pedal response..I've had the truck for 40k now and it has 110k on it now and I don't know if the filter was ever replaced.
Thanks guys.
Justin
