injector size
Old Apr 13, 2002 | 10:15 AM
Donate54's Avatar
injector size
if i want to put bigger injectors on a speed density engine truck, what needs to be done? will i have a problem if i only change the injectors (from 19# to 24#)?
Old Apr 13, 2002 | 03:18 PM
dvldog458's Avatar
Donate,
When you start playing with injector size your gonna have to get a fuel/air ratio meter...........and an adjustable fuel pressure reg,but i think you already have a BBK reg,so your halfway there.
When you put more fuel in.......your gonna need more air and exhaust,(i.e. intake/heads.
If your just looking for a new set of injectors (19lbs) i have a Ford motosport set never used,still in the box.
Jerry D
Old Apr 13, 2002 | 03:22 PM
Donate54's Avatar
well i have an adjustable fuel pressure regulator and an air/fuel gauge, and a friend of mine just replaced his 24# injectors with 36's, so i was wondering if i would see any gain by switching to 24#.
Old Apr 13, 2002 | 06:53 PM
FORD302GUY's Avatar
24 lb injectors are way to much fuel unless your truck is heavily modified. Performance gain will be zero-possibly worse.
Old Apr 14, 2002 | 02:43 AM
TF's Avatar
TF
dvldog458,
I've been thinking about replacing my fuel injectors for some time now. 19# are the stock size, right? How much do the fuel injectors cost? If Donate54 doesn't want them, I would be interested if they don't cost too much. I'm still recuperating from the intake manifold!!!
Old Apr 14, 2002 | 02:54 AM
signmaster's Avatar
Done properly you should get a chip burn if you go to larger injectors. Even though the compute will attempt to adjust the mixture, you can exceed the limits of what the computer will do.
I also agree, really nothing to gain unless you add a lot more work. The stock 19 lb injectors will handle most bolt ons.
Old Apr 14, 2002 | 12:41 PM
Donate54's Avatar
TF,
i dont need dvldog458's injectors, so they're all yours
Old Apr 14, 2002 | 12:49 PM
Macgyver's Avatar
new injectors would cost you around $550 :-(.
Old Apr 14, 2002 | 01:45 PM
bjoern's Avatar
You might want to check out http://fiveomotorsport.com, I got a set of 8 Bosch Design III Injectors there for $150.
Old Apr 14, 2002 | 06:39 PM
Macgyver's Avatar
link dont work
Old Apr 14, 2002 | 10:27 PM
bjoern's Avatar
Thumbs down
Because the clever PHP script here includes the "," in the URL. Just delete it and it'll work.
Old Apr 15, 2002 | 12:39 AM
Donate54's Avatar
even without the comma the link still doesnt work
Old Apr 15, 2002 | 10:33 AM
bjoern's Avatar
It worked fine for me yesterday. I also get a DNS error now. Seem to be technical problems with the domain resolution. Try again later today or tomorrow. The link is definitely fine (without the comma)!
Old Apr 15, 2002 | 02:05 PM
bjoern's Avatar
Yup, working fine for me now...
Old Apr 15, 2002 | 02:29 PM
Donate54's Avatar
now its working for me
