injector size
Old Apr 16, 2002 | 08:49 AM
dvldog458's Avatar
TF,
I only want $100 for these injectors.They are brand new never used or installed still in box from Summit.
I bought them to put in my truck. As soon as i got them,i came across a good deal on some 24#ers
And thats when it all began.
Thanks.
Jerry D
Old Apr 16, 2002 | 05:15 PM
TF's Avatar
TF
That sounds like a good deal to me!!! What's involved in swapping the fuel injectors? Is it a complicated process, or can it be done within a couple hours? If it's not too big a job, you've got yourself a deal. If you can fill me in on some details, I'll let you know for sure. Thanks!!!
Old Apr 16, 2002 | 10:44 PM
dvldog458's Avatar
It's a pretty easy job.
You have to take the plenum off so you can get to the injector rail/injectors.
Relieve fuel pressure from fuel rail (the thing that looks like a tire valve)
Pop the rail off and remove the injectors.
Install the new injectors in the lower intake manifold.....use some lube on the o-rings.
Then you snap the fuel rail back on.
If you use your sevice manual it will break it down even further.
Hope this helps.
Jerry D.
Old Apr 17, 2002 | 04:49 PM
TF's Avatar
TF
Man, I wish I would have known about this 2 weeks ago!!! I would have done it when I got me new intake manifold! But I'm thinking I might as well get them now while there's a good deal, that way, when the time is right, I won't have to spend an arm and a leg. You should be able to e-mail me by clicking on the e-mail button, and just let me know how you want to work this out. Thanks again!!
Old Apr 17, 2002 | 05:13 PM
PKRWUD's Avatar
That's an awesome deal.
Take care,
-Chris
