engine temp
Old Mar 13, 2002 | 07:17 PM
Donate54's Avatar
engine temp
my truck has been developing a little problem this past week. after about 20 minutes of driving, the temp gauge (stock gauge) is reading a lot hotter than it used to read. the needle is around the A (you know how the gauge has no numbers, only has the word NORMAL going across). my truck used to always hold steady around the O after warming up. i thought maybe it was the electric fans, so i uninstalled them and put in the stock clutch fan, but i still have the same problem. after i shut off the truck, most of the coolant comes pouring out the reservoir. im gonna try changing the thermostat tomorrow, but if that doesnt help, what else could it be? i checked for leaky hoses but theyre all intact. the water pump was replaced about 5,000 miles ago so i really hope thats not the problem. is there any way to test to see if the water pump is going bad (without having to install a new one)? any suggestions? thanks!
Old Mar 13, 2002 | 07:30 PM
Macgyver's Avatar
if the temp steadily rises and doesn't drop any during this time . the T stat is stuck . hows the oil pressure? has your pushrod/lifter problem been fixed ? has it gotten worse? didn't you also have a leaking rear main seal? does it also do this sitting at an idle . not driving? does it do it on the freeway? pull the t stat read what temp it says it is on it . place it in a pan of water . heat it on the stove with a thermometer in the water . check to see if it opens at the temp it says it is on the t stat . if it doesn't replace it . hell they are cheap enough . if ya got it out replace it just for S**TS and Giggles. but the pan test will tell you if it was stickin or not .
Old Mar 13, 2002 | 08:10 PM
Donate54's Avatar
oil pressureis holding normal. rear seal has not been fixed yet, but i check the oil every day and add oil whenever it needs it, so its never low on oil (the leak is a very small one). lifters were making noise due to the fact that the truck was low on oil before i found out the rear seal is leaking. thermostats are cheap so im gonna go and buy one tomorrow and replace it, hopefully that will fix the problem.
Old Mar 14, 2002 | 02:01 AM
dvldog458's Avatar
Donate54,
Just keep an eye on the way the t-stat comes out.
One time i put it in backwards........boy did i feel like a jackass.
Thank god i noticed it before it got too hot.
