My trucks getting there...one more prob.
Old Feb 23, 2002 | 01:34 AM
fivept0's Avatar
Post My trucks getting there...one more prob.
My truck is finally starting to run good...But i have one more nagging problem. It has to do with the front brakes. (i think) The problem is: when i brake it feels like the drivers side front wheel is almost bouncing off the ground. The truck also pulls to the left when braking. These symptoms seem to be aggrivated while braking down an incline, or during heavy braking. I can also hear an audible noise while this is happening. Does this sound like a warped rotor? Or something else? Its hard to tell if the pedal is pulsing or not, but it does feel like it is pulsing a little.
thanks alot,
scott
Old Feb 23, 2002 | 01:37 AM
Macgyver's Avatar
sounds like a slightly warped rotor .
Old Feb 23, 2002 | 01:46 AM
fivept0's Avatar
Good, I need to replace the pads anyways. Do I need any special tools for the hub? I've never worked on a 4x4s brakes before.
Old Feb 23, 2002 | 01:48 AM
Macgyver's Avatar
neither have i .. oh i forgot one pic . i am uploading it now
Old Feb 23, 2002 | 09:30 AM
inski21's Avatar
On my 93 (think yours is same) it was quite a project. But, if you think of it as a regular rear drive front brake job(hub, bearings,spindle) you can do it. You'll need the big socket(tabs on it) that loosens/tightens the bearings. Maybe an air hammer or bf chizel and bf hammer will be needed to get spindle and rotor off.
Rotors and pads are cheap. Consult Alldata if you can or check a manual.
Old Feb 23, 2002 | 04:45 PM
FORD302GUY's Avatar
You do NOT need to take spindle off to get the rotor off. the only reason the spindle would have to come off is if you needed to get the axle out:which you dont.
If you take the wheel bearing nuts off the rotor will slide right off the spindle.
Old Feb 23, 2002 | 04:56 PM
SPROCKET_X's Avatar
rotor should slide right off but usualy doesn't...might need to tap it with a mallet
Old Feb 23, 2002 | 06:28 PM
inski21's Avatar
Yep, you don't have to take the spidle off. I recently did my u-joint and brakes at the same time. Also recently worked on a 98 Suburban 2500 4x4, which everything has to come off. What a nightmare. Well, its all bleeding together now. Oh no.
my bad.
I'll stand in the corner now.
Old Feb 24, 2002 | 02:11 PM
fivept0's Avatar
Thanks for the help guys.
What type of brake pads would you guys recomend for towing? Maybe some with a little extra bite?
Old Feb 24, 2002 | 03:37 PM
inski21's Avatar
In the Keystone Ford catalog they have EBC 6000 series (mail order only, no price given, must find dealer/shop).
pt# DP61261 94-96 F150 4.9/5.0/5.8
In J.c. Whitney "Ford" catalog they have drilled and slotted rotors.
$79 ea. 47DU0302N + 47DU0303T
Titanium ti Pads 55DU5893X 24.95 set
Old Feb 24, 2002 | 03:59 PM
inski21's Avatar
Hows the hood?
Old Feb 24, 2002 | 05:42 PM
fivept0's Avatar
Inski:
Does keystone ford have a web site?
I'm kinda leary to use drilled rotors...i've heard they crack and warp pretty easy.
I did get the hood open ...look at my hood post to see how.
thanks,
scott
Old Feb 24, 2002 | 09:50 PM
inski21's Avatar
Keystone is a wholesale thing. They print catalogs, but don't give prices so the retailer can fix their own prices using Keystone wharehouse. You have to find a company or truck accs. store that retails w/ them. I have 2 near where I live, the owner is pretty cool and lets me argue pricing with them.
www.key-stone.com
www.ekeystone.com
www.key-stone.com/keypartsrsl/ dealer locator
Yep, I'm steering clear of drilled rotors also.
