Mpg Savers
Old Nov 14, 2013 | 12:22 AM
SouthernBoy13's Avatar
Mpg Savers
Anybody know some good ways of saving mpg on the 95 F150 5.8 351's. Anything could help. Name:  image-3.jpg
Old Nov 14, 2013 | 12:38 AM
jdeacon's Avatar
driving like a grandma. changing how you drive will net you better mpg increases than anything you can do to that truck. other than that? p series highway tires
Old Nov 14, 2013 | 01:19 AM
Coast up to every single stop sign and light from way back. Try to time it so that you barely have to brake, if at all. That works absolute wonders, though I never am able to make myself do it consistently. And keep the RPM below about 2k on take offs. But yeah, essentially drive like a blind, arthritic 95 year old.
Old Nov 14, 2013 | 03:48 AM
F150redneck's Avatar
When coming to the crest of a hill punch that SOB put in nuetral and see how far you can coast :P Your driving habits is all you can really do like deacon and KMAC said. Hard to get better mpg's out of a 351!
Old Nov 14, 2013 | 06:11 AM
StrangeRanger's Avatar
Tonneau cover
Synthetic fluids
Keep your tires aired up
Hotter thermostat
Install a vacuum gauge and use it to control your throttle foot
Old Nov 14, 2013 | 09:06 AM
Roadie's Avatar
Reprogramming will help too if you drive it easy afterwards. Keep the tires pumped up to maximum pressure. The Michelin energy tires or similar will help too. Wide tires hurt mpg.
Old Nov 14, 2013 | 09:15 AM
I gotta have a 4x4 . Is there any engine stuff that would help keep it better. I just don't feel it's doing as good as it should.
Old Nov 14, 2013 | 09:18 AM
dewalt17's Avatar
I would do a tune up if it hasn't been done in awhile. Worn out plugs won't do you any favors.
Old Nov 14, 2013 | 11:49 AM
I have done a tune up. But I think I have a clogged Cat How would I know. Cause when I am driving the check engine light comes on, randomly.
Old Nov 14, 2013 | 11:57 AM
Roadie's Avatar
Check the code. Autozone or Advance will do it for free. It's most likely an egr code.
Midas checked a cat for me one time. They did it by cutting a hole in the exhaust pipe ahead of the cat and checking the pressure before the cat. In my case it was something else.
Buy some Gumout fuel injector cleaner for high mileage engines and put it in the gas. It works! It will clean up your injectors and combustion chambers. Walmart sells it.
Old Nov 14, 2013 | 12:51 PM
Not all parts stores can check EEC codes. The only one here who can is one of the O'Reilly's. If it were OBD2, everyone can check those.
With that said, a 351 in a truck gets crappy mileage no matter what you do.
Old Nov 14, 2013 | 03:29 PM
That's the thing. They can't check my engine light cause it goes off when I cut the vehicle off.
Old Nov 14, 2013 | 03:34 PM
Old Nov 14, 2013 | 03:36 PM
How do you replace the exhaust manifold gasket? I know I broke the one on left side of block?, cause you can hear it.
Old Nov 14, 2013 | 03:59 PM
Pockets's Avatar
Originally Posted by KMAC0694
...... But yeah, essentially drive like a blind, arthritic 95 year old.
Omg my side hurts from laughing so hard
That's the best way though but also the least fun haha
